First time lumed dial..
I'm very satisfied with how this dial turned out. I'm building and Elgin pocket watch conversion into wristwatch and wanted a vintage military dial look.
I had recently purchased a lume kit but hadn't had the chance to use it yet. I design the dial with bold outlined numerals for the purpose of filling with lume. It really turned out better than I ever hoped!
The first dial I did turned out very acceptable, except that I had another issue with it and had to start over. I learned quite a bit just from doing that one dial.
Once I had the printing plate made I repainted the original Elgin dial to a flat white. I then Inked the plate and printed the new dial. Once everything was dry I then slowly added the lume using a 100 - 0 paintbrush which is about the size of a watch Oiler. I went around the dial 4 times adding a layer little by little. I'm very surprised just how much Lume this process adds. The markers have a nice three-dimensional heft to them...
Edited by DJW
  • Like 11
I will try to put together a walk-through of the process of dial printing along with creating the plate itself. Honestly I spend more time on the computer designing the dial layout then it takes two create the actual plate or print the dial.:wacko:
  • Like 5
  • Thanks 3
  • 5 months later...
Yes!!! I've been wanting to that to make dials for the Chinese movements that seem to not have any unless you but some brand that uses the dial. I know they have number stickers but if I could design my own I would simply be in heaven!
Hi again DJW, if it makes life easier for you, do you have a suitable link to a website which explains the dial printing process please? As you might have noticed, the natives are restless and want to know more[emoji6]
20 minutes ago, Deggsie said:
Hi again DJW, if it makes life easier for you, do you have a suitable link to a website which explains the dial printing process please? As you might have noticed, the natives are restless and want to know moreemoji6.png
It's nothing secret, but beside the printing "machine" itself, the need to use a precisely engraved plate places the job largely outside the domain of the average hobbyist and even professional watchmaker  I think that if you can find someone that makes the plate on your design, or are willing to spend pretty good money on a CNC machine that does that, you could be game. I don't know if 3D printing would do a good enough plate. Fact is, at the present time dial making/reprinting specialists are rare.
  • 3 months later...
This is incredible! Awesome job! I have the same movement I've been trying to figure out how to do the dial forever. I've thought about the whole water slide decals, having vinyl made, trying to have someone hand paint it, nothing is ever as nice as the real deal like you have. I bow at you completing a project I've only begun to think about! It's beautiful.
Sent from my Moto E (4) using Tapatalk
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
