Hello from NY
luskombi
Hi everyone,
I've been a member of this most excellent forum for some time now and I'd like to introduce myself properly. My name is Tim and I live in the fingerlakes region of New York state. I became reinterested in watches several years ago and it's been downhill since. Seiko is my preferred brand at present of which I've accumulated a small collection.
A mechanic by trade, watch tinkering was sure to soon follow and it did. So, many, many thanks to all of you that I've learned so much from , I hope one day I'll something of value to contribute. And to you Mr. Lovick for your truly outstanding videos. I've seen them all at least a thousand times. Lol
So nice to be here, Tim
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
