My new timing machine setup
Mark
My new watch timing machine setup.
I ditched the bulky laptop (well it ditched me as it just stopped turning on lol)
Running Graham Baxters escapement analyser software on a windows 10 tablet.
The tablet didn't have a sound input socket so I thought I would try a cheap USB sound card (about £4) and connected the microphone which was a Greiner model modified by Graham and it all works like a treat.
The great thing about these vintage microphones as compaired to the modern timegrapher models is that you can get a full 360 degree turn.
