Has anyone worked on a seiko 619-7071 case?
jnash
Have a weird one here.
I'm sure im missing something as the glass does not fit.
I think im missing a crystal gasket but even the inner ring seems loose.  any one have any pics of the breakdown of the case or a manual? thanks in advice
it was together when i took it apart, but im thinking glue was involved to bodge it
Thanks in advance!
J
Does it rotate. Is there any small gears on the bezel. If so there should be a gear on the stem to. And maybe you are missing the thin spring that should sit over the inner bezel. A thin wavy washerlike spring.
Nope, I've done 100s of Seiko's , this is a fixed inner bezel. Just wired pi's online don't really help and you can see with all of them that there is what looks like a gap !
Sent from my ONEPLUS A3003 using Tapatalk
Yes. You have to remove the bezel to gain access to the crystal. Then you press the crystal out and the chapter ring will drop out. The crystal hold the chapter ring in. Check out the Seiko Watch forum at thewatchsite.com or google Seiko / citizen watch forum. Here you can download the Seiko casing guides
I've done all of that, the problem is that everything is loose, I think something here is missing suck as a glass gasket etc?
Casing guide is your friend. Will show exploded view of case with all parts and gaskets
There must be some sort of crystal gasket? Looked at jules borel and the gasket is a EC3340B04. That is in lots of seiko models. http://cgi.julesborel.com/cgi-bin/matcgi2?ref=io]H[DeEX
Other then that i see no thing that is missing. http://cgi.julesborel.com/cgi-bin/matcgi2?ref=SEK+CS%236139-7071&submit=Search
Edited by rogart63
Thank you however as you can see, the seiko in question is in fact a chronograph (2 buttons , one crown) with a 6139 movement, therefore caliber 6139 and the case number is 7071.
It would be great to find a guide for it to put my mind at ease! - i have never had a issue with a seiko before!
Hi,  I have a 6139-6002 which has chrono buttons and the case data shows F2-Screw2 for 6139-600 so I suspect your case is 707(1).  This then has case data as F3-Screw3.
The F3 is the data for the glass fitting only (see page 13 on doc) and the Screw3 is the case assembly with all parts.
My 6139 has chrono buttons but the case info fits so I can only assume that the chrono buttons do not affect the case assembly as such and that the extra digit brings in the chrono or other form of the basic case.
Hope this helps a little.
    • @JohnR725 that's very helpful.  I appreciate the time you took to give those instructions and post the pictures.  below is a picture of my staff, which looks identical to the ones you posted.  The approx measurements I got are: .772 on the left part of the staff; .715 on the right side of the hub; the hub is 1.107; and the overall length (minus the broken pivot) is 5.248; which seem to line up with the measurements you posted.  I didn't think to measure the pivot, which I'll do if there's enough of one left on the staff.  Thanks again.
    • Thank you to both of you!  I've been somewhat derailed by this quandary for a couple of days now. I am guessing that the point of the wider tweezers is to support the whole spring at the same time in an effort to prevent it going under tension... I have already discovered the Zen of a clutter free space, and trying to keep my work well away from the edge, however the most terrifying of the flights wasn't so short, I had my work in the middle of the table and nothing else around.  That particular launch was towards me.  I distinctly recall feeling the spring hit my left hand as it escaped.  I only found it by dumb luck, on the floor, between the legs of my chair.  I need to order a pack of replacements just in case.  I think I recall a thread discussing where to find them, and the differences between the clones and the authentic ETA ones, pointing out that they're not interchangeable (the clones being longer IIRC).  Now I just have to find that thread again.  What I haven't mastered is the zen of the search function here.  I'm sure I"ll get that down eventually. So this is similar to, but different from one of the posts I had found in my original searches (or maybe I'm just hallucinating, I can't find the post I thought I remember).  The bits about the corner filled in a gap in what I'd read before.  At least I have a more clear picture in my head about what needs to happen now.  Yes, I've learned about how touchy these springs are.  What I'm not sure I have a good grasp on is the understanding of what causes the spring to flex, other than to say "the slightest little touch"  I think I'm going to try a small bit of Rodico to position the spring next time.
    • I think it's stamped on the inside cover. 309 I think.
    • Hi all, needing a little help. I have an old Casio AQ-321G, but have no idea what battery it takes. I've looked around online, but cannot see anything... I see a 309 stamped on the case back, could this be it....? Can you please help, below are some pictures:
    • The radial teeth are for hte seconds register, and the other (which is simple and doesn' take away significant torque from the train) for the minutes register.
