How long is edit window open?
It seems briefly after posting there is the opportunity to edit posts, but the window quickly closes.  Anyone know what the setting is?  Personally, as someone quite prone to typos, I'd like it left open, but if its to close I'm curious how long one has.
thanks
Being a Mod, there's no time limit for me on editing any posts on the Forum, but - as I recall - it's only about 2-3 minutes before the edit facility closes.
There's a reason for the time limit on this sort of forum software - which is to prevent statements being altered. On other, more argumentative forums, this can be crucial. Luckily, we're not that kind of forum and, if we were, I and the other Mods would be wielding big sticks. This is a friendly and supportive site, for which I'm sure we're all grateful! However, the principle of letting original posts stand is a good one.
If there's something which you obviously need to amend with hindsight, contact one of the Mods and we'll check and change it for you - at no extra cost! :thumbsu:
Thanks for the explanation.  I'm on one forum that never closes and really like it.  Its maybe 5/10 on the augment scale (good guys but its technical so some really dig in on the need to be right).  No one changes posts, it's just the cultural norm, peer pressure I guess makes it unacceptable to do so.  Me, I make a lot of typos and skipped words., mild dyslexia?  hands can't keep up with brain?  whatever, but I hate just leaving them there forever yet its to frequent to bug someone about.   I really prefer the open ended thing, but I'm the new guy, so when in Rome.....:)
Even on friendly forums only allowing editting for a set period is needed.
I help manage a forum about toy steam engines and we had 2 incidents that made us change  from allowing editting for ever to about 15 minutes.
The first one was a refernce thread on screw sizes used on brands of steam engines. We had a regular forum member that managed that thread. People PMed him the screw sizes and he then editted his post and and added the information.
One time when editing his PC crashed and somehow it deleted everything from his post, about 2 years of work lost.
The other time we had a reasonably active member for what ever reason got upset and decided to leave, but must of spent a good hour or two editing every post he did and replaced his posts with either emojis or swear words, an extreme case of pettiness especially as we never even found out what upset him.
Either way only allowing editing for short periods stops this problem.
the  destruction of the  library at Alexandria  is very interesting HISTORY,  but nothing to do with watches.  the  author should have an opportunity to remove  it.  at  any time.     off color or argumentative  post should be  elimitated by a administrater.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
    • Don't forget Mark is a hard working watch maker so he is also tied up with work. I'm sure he is keeping his eye on this forum making sure it is running along nicely.
