Tempus World Timer
Just picked this beauty up off the bay. Much better condition than I originally bought. Definitely needs services. Can anyone tell me anything about Tempus? Can't seem to find ANYTHING on them. Beautiful timepiece though!eae0d70143e2bef018886df043671d40.jpg236c57beb7e6a79a23d414947977e4ca.jpg99d10854fcac3c90f730948330076315.jpg
Sent from my SM-N900V using Tapatalk
They where made by Sindaco Ltd so do a search for that company and you will find information on them, The watch will have a pin pallet movement which could be anywhere between 1 to 17 jewels but probably one jewel.
    • Snap! I recently finished my Gruen 510 movement - though the case for mine is in a rather sad state; I'm going to try re-plating it (in nickel, it's not a gold one).   Re. the screws, I got a few of the one gram mixed batches from ebay. I've only needed a couple of screws for things so far, both rare, minuscule types - but both in the mix, after enough time sorting through them! The ones such as normal bridge screws are quite common in those lots.
