What about this.
oldhippy
Well where to start,
"This clock is a rare exceptional french original brass and champleve style enamel 4 glass regulator mantel clock, it has its absolutely amazing look to it all in great condition for age, the case has a superb original finish to it with only minimal age wear as can be expected"
The clock is certainly not of french origin the diamond trade mark was used by a Chinese manufacturer making both clock's and watches in Shanghai, the use of the word regulator is wrong it would depend on what definition of a regulator you would use but this clock could only be wrongly described as a regulator, its certainly not champaleve but he does say style so I will give him that.
As for it striking as it should I cant see it doing that at the moment with it set as it is.
The movement has a Brocot escapement and the quality of it could only be described as plain "Nasty"  a true horror of the horological world made from cheaply pressed out parts and finished by sweat shop workers on a dollar a day.
The description reads like a turd polishers dream but at the end of the day its still a turd.
It has however attracted a bid for twice what its worth.
Where would you like me to start?
1. Painted hands made from thick steel rather than thin blued steel
2. Brass screw to retain minute hand rather than washer and pin
3. What does "Trade Mark" mean on the dial? Wouldn't get that on a French clock
4. Pan head brass screws instead of machined blued screws or pins
5. Gong made from an old coat hanger
I'll let others continue...
28 minutes ago, StuartBaker104 said:
33 minutes ago, wls1971 said:
More than twice - it's got £20 postage!!
"You are more than welcome to personally collect any item free of charge"
 how very kind of them to allow no charge for personally collecting, but I personally find this next statement in the description truly unbelievable,
"This is a perfect investment clock and a beautiful display piece and a stunning brass, ormolu & champleve enamel clock which i am sure you would agree. Looks absolutely fantastic wherever it is displayed":wacko:
Everything in that statement is incorrect
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
