Croton Aquamatic
anilv
Morning guys (at least in South East Asia!)
Digging thru my collection to find something to wear this Friday I pulled out this.P_20170721_064548.thumb.jpg.6ba8170cef529fc1026124461c20bb25.jpg
A 'Croton Nivada Grenchen Aquamatic'.. now that's a mouthful, as the actress told the bishop.
Inside we find a nicely finished ETA1256 movement. This would be one of the first ETA automatics. ETA kindly provided instructions on the rotor (hammer)... "TO REMOVE HAMMER ASSEMBLY UNSCREW 3 SCREWS 'A' ". Probably they were worried that watchmaker of the day would have problems with these newfangled technology!.
Croton were one of the early innovators of waterproofing and they achieved this on early models with a case back that was fastened by 4 screws. These might have worked back in the day but they're just a pain today as the screws are usually badly damaged. This example is a bit recent and has a screw down case back. I wonder is the stamped 61S denotes year of manufacture? Groton watches are not too rare but stainless steel cases are less common and you usually find basemetal cases watches.P_20170721_065505.thumb.jpg.d48310ee9b66767144c0821a9d838743.jpg
I've got it on a vintage brand which is super supple and suits the watch. It is similar to a 'bonklip' in function.
This is the bandmakers mark.
Cheers!
Anilv
The way I understand it, Eterna started ETA to brand their ebauches so that the companies who used their movements could not be said to be using Eterna movements.
So if a higher end brand were to use Eterna, they would not want to be associated with Eterna (lower priced range). Customers would say why pay more for the same ?
Conversely, If a cheaper brand were to use an Eterna movement... who would buy an Eterna? You would be getting the same quality movement at a lower price!
We see a lot of high priced watches used ETA movements (the ETA 1256 was for a while a favourite of Girard-perregaux) but you also see it in some weird brands.
This association between movements works elsewhere. The omega 1481 was also used in Tissot where it was called the 2481.  Apart from the nicer finishing on the Omega.. you will just be paying more for the name.
Longines started their slide when the started using ETA ebauches, but this only mattered to the cognoscenti.
Anilv
Since they went down the ETA route I've kinda lost interest. I had a chance to handle a Legend Diver some time back but it didn't do anything for me. Having a 2836 inside didnt help.
Sad because they made some nice watches back in the day, I especially like their Admiral series (although they are some with designs only a mother could love!).
I still have 2 watches powered by  cal 990 automatic which are as good as it gets when it comes to swiss automatics. Thin and capable.
Anilv
  • Similar Content
    • Yes, it looks like GT Revue 30. Doctor, You can not replace escape wheel by the dimensions You listed. One needs to know much more things like number of leaves of the pinion and it's diameter, the position in high of the table and the pinion, the hight between the pivots, the exact pivots diameter... And then, even if suitable wheel is found, one will need to know how to adjust the pallets position correctly. Restoring antique movements is something different than replacing parts. In older movements parts are not interchangeable, this means spare parts do not exist. Here the case is different, but still escapement adjustment will be needed if a wheel from a donor is found. So may be it will be easier to restore the donor for You...Restoring antique movements usually means making of the parts needed and this requires knowlage and working on lathes skill. In this case repivoting of the wheel is the natural solution, but there is a long way that one must walk untill getting ready for such work.
    • I was looking at Essence of Renata, a chemical used a lot for cleaning hairsprings: "Specially prepared solution for degreasing watch and instrument components. Indispensable for degreasing hairsprings." Looking at the MSDS you can see this is just pure n-Heptane, so could be an option for those who don't want to use the chlorocarbons or hexane?     HF6013 - Horological Essence COSHH Safety Data Sheet Horological Essence_0.pdf
    • Welcome from a fellow Seiko enthusiast, there are lots of us on this forum.
    • Nickelsilver is right, movement diameter and keyless works ‘fingerprint’ are important for identifying movements. That said, this appears to be a 7 jewel version of the a Revue 30 movement.  A quick search with google turns up parts movements, and individual parts should be quite easy to come by.  Hope that helps, Mark
