  • 0
Tmuir
Not another oil question
Question
I'm pretty well set up for oils for wrist watches, but not so for pocket watches.
I'm yet to buy Moebius 9020 which I will be buying on my next order from Cousins.
I've just cleaned and serviced an 8 day car clock which I'm guessing is from the 20s or 30s which is essentially an oversized pocket watch.
Can I get away using 9010 on the pivots or should I wait until I get 9020?
Also I currently have 9415 for the pallets which I know is the recommended oil for watches over 19,800bph.
Should I also be investing in 941/2 for the slower beat watches, or will 9415 be ok too.
Share this post
Link to post
12 answers to this question
  • 0
I don't use 9020 anymore. I use HP-1300 for the center and third wheels, 9010 for the fourth wheel and escape wheel. I believe you can use 9415 on all pallets - but would defer to the others here.
Stu
Share this post
Link to post
  • 0
If you want to stick with Moebius use  clock oil 8031.
I always preferred JD Windles Clock Oil for all clocks apart from clocks that had a platform escapement, then it would be a watch oil but not too thin.
Share this post
Link to post
  • 0
I have read that 9415 is especially developped for high speed escapement, and can cause loss of amplitude on slower beat watches. For that reason, after a long time using only 9415 on pallet stones I have recently invested in 941/2.
It is a lot thinner than 9415, but I can't say that I have noticed a difference in performance. I wanted to experiment with both on the same movement and measure the difference but haven't got arount to it yet....
As for the car clock, I have worked on a few and i used 9010 on the balance jewels, and D5/ HP1300 on the rest of the train with no issue, I could not justify yet another type of oil for this application, the clocks I was workin on were not exactly high end!
Share this post
Link to post
  • 0
I had never heard of JD Windles Clock Oil before, so I looked it up.
The price is certainly good so I have added that to my list for my next order from Cousins as I'm not completely happy with the oil I have been using on clocks and 50ml should last me for ever.
Share this post
Link to post
  • 0
I have used 941 on low beat movements many times.  I read that it is advised to epilame the pallet stones and escape wheel when using this oil which I have always done.  This probably because it is very thin and likely to migrate more.  That is why epilame is advised.  Epilame is also known as Moebius Fixodrop.  I gather the 9451 is more like a thixotropic loose grease that stiffens up when the pallet stones hit the escape wheel teeth.  It will probably stay in place better at the higher speeds of the escapement parts.
Share this post
Link to post
  • 0
OOPS!  Brain malfunction !!
Should have said that when the pallet stones/escape wheel teeth hit the loose grease in the working zone it reduces the viscosity making it much thinner. When the working zone ends the loose grease will thicken again to help 'stay-in-place' properties.  Makes more sense this way !!!!
Share this post
Link to post
  • 0
Pallet stones should not be greased. Not clock pallets or watch pallets, don’t know about quartz movements.
Moebius 9415 is a lubricant specifically designed for pallets and is recommended for both mechanical clock and watch movements.
It is a thixotropic fluid which means that under static conditions it has a relatively high viscosity which, as Canthus has pointed out helps it to stay in place, but which stressed in some way (for instance when suddenly squeezed between a pallet stone and an escape wheel tooth) becomes momentarily much less viscous allowing it to flow more easily (thus lubrication the interface between the pallet stone and the escape wheel tooth).
It is technically a grease and as such it is perfectly acceptable (even recommended) to lubricate both clock and watch pallet stones with a grease so long as it is 9415 or some equivalent. It would however be entirely inappropriate to do so using something like Castrol LM:biggrin:
Share this post
Link to post
  • 0
I'm currently working on a Waltham Hunter which someone has flooded with something that looks like some kind of all-purpose household oil. The watch needs a new mainspring so I'm waiting for it to arrive before I clean and lube the watch. I am wondering if I can use the same oils/grease as a 6497 as I have experience with that type. Any advice would be helpful...
Share this post
Link to post
  • 0
Better explanation from Marc, thanks.  Being ex oil industrial oils 'a grease is a grease' to me no matter what form it takes, so I may have misled some people in my explanation.
Don't know what 6497 is, but 9415 is very thin and may have limited use.
For those interested I have attached Moebius' sales spec book which describes all their oils (at the time of publishing, may be more products now), typical applications and some handy movement/lubes pics.
moebius-specsbook.pdf
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
    • In highland terms, we're practically neighbours,
      I'm on the opposite coast and a bit higher up, about 150ish miles, near Skye, I pass near there on the way to see my son in Glasgow though.
    • I used to have a golf club that was called Big Bertha, I wish I had as good timing in my swing as a regulator has
    • Strangely enough, I tend to do something similar.
      The test watch on the left arm, and a quartz number on the right. Recently I have been using a Swatch as the watch to compare with. Today, however I've been wearing a rather odd watch that came with a bundle of other stuff. It is the most generic watch I have ever encountered. It has absolutely no branding on it. The caseback is completely blank, the strap (which does appear to be leather).. blank..  and it arrived in a completely unworn condition. Not a mark on it. Quality wise, it is reasonable. Not a dollar store watch, but then again not something you would spend more than maybe forty bucks on, new. So today I stuffed a battery in it, and substituted it for the Swatch. This would actually make the ultimate crime of the century watch, since it appears to be completely untraceable. The styling is very much what you would expect for a completely vanilla watch. Not unpleasant, but not particularly inspiring either. Having said that, it wouldn't look out of place next to any of the modern "designer" watches.. yes you "Daniel Wellington".. I'm talking about you and your like.
    • As it’s my clock it’s called big Bertha.
    • I thought I could share my journey servicing an ETA 205.111A  Autoquartz. Yes sometimes I just get an urge for something different and now it is a bunch of quartz movements in my scope.
      Today I have taken it apart and made a small PDF describing the process, might be one or two interesting shots in it.
      When I received the new capacitor part two will be released.
        AutoQuartz_Disassemble.pdf
