My engagement watch was a Briel, which turns out to have a 0S60 Miyota movement.
I paid goldsmiths to replace the battery, boy what a mistake. When I collected it the crown came off in my hand. Goldsmith said they can't repair!!! They paid me £250.
So this is when I did some research and took the back off the watch. I believe the stem is still in the watch. But I think I can repair by replacing the stem and crown. I still have the crown.
Could some one advise what stem I need and how can I attach the crown, doesn't appear to have a thread but I think it should have. I can get more photos if needed.
Many thanks
Strange. Can you provide a picture of the crown. It would be helpful to know if the stem simply came un screwed or snapped off leaving some of the stem left in the crown.
I realise you had a bad experience with one business but I wouldn't completely disregard seeking out the help of another, at least if there's any watch specialists around your area, The watch mainetence/repair work of jewellers, particularly large chain jewellers (like goldsmith's) often leaves a lot to be desired and what's 'impossible' for them is childs-play for someone who is a watch repairman first and foremost.
From the first photo I can see part of the stem, I would say its broken off. The button screws on.
Stem from here. https://www.ebay.co.uk/i/253007986837?chn=ps&dispItem=1&adgroupid=13585920426&rlsatarget=aud-133395220866%3Apla-142405555266&abcId=&adtype=pla&merchantid=9391734&poi=&googleloc=9041119&device=c&campaignid=207297426&crdt=0
Photo of how to take the stem out.
Excersise extreme delicacy when pressing the stem release. It is very common for people without the proper experience to basically damage that mechanism. You'll need to press on it while gently pulling the remaining piece of stem from inside the case with a pair of tweezers. And the stem may need to be pushed, clicked in to the proper position (fully in) otherwise the stem release leaver wont be there where you're pressing.
Edited by Ishima
My thanks to both Oldhippy and Ishima. All responses are excellent.
I think old hippy is correct in that the crown was stressed at some point and does appear to have snapped of. I intend to get some better photos later as per Ishima.
I also take your points Ishima. My experience with Goldsmiths was very emotional as to have a very important watch (emotionally not in terms of £'s value) returned broken was a true shock , the lady on the counter at my local store was near tears and I hadn't said anything. My true concern with Goldsmiths is that if I can research that stem replacement is relatively simple, Goldsmiths should have been able to replace, but I suspect as with most large scale businesses of this type they went for the easy option and gave me money to which I now have a very nice Hamilton Crosswind and the potential to repair my original watch.
Also, looking at the watch removing the remained stem may be a step too far for me as it may not come out easily as there is little if any to grip so I may have to find a repair support locally (not that many around here Tamworth, England) that according to google. I have sourced a stem on ebay for £5 from USA so, if will see where I go.
But again to both Oldhippy and Ishima my thanks for your time. I will post photos later.
thanks
Hi all,
Just been emailed the stems info below:-
065.453 - 1800 Length
065.533 - 2400 Length
065.557 - 2400 Length
How do I measure length of stem required?
You will need to cut the stem to the right length when you fit it. For this it is better to fit - measure - adjust until it is right rather than to cut to a "spec" length and fit blind. See here for an excellent walk through by Geo.
As for the crown, if it is stainless steel or plated brass your best bet is to use alum to disolve out the remaining stem leaving you with clean threads to fit it to the new stem.
great responses, my thanks. Looks like I have a little work to do.
Here's some more images. Notice in the crown it looks like it snapped off leaving the stem head in the crown, but I could be well wrong.
The stem end is like any other stem.
That bit I think is part of the crown.
PS - Sorry about the DNA under the crown [emoji33]
PPS - Got the stem from Leosics in the UK.
Sent from my Honor 5c
Does not look good, Check if you can find a suitable replacement on Cousins UK or other source.
If you can't get a new crown you can drill and retap the original one. You'll need to find a watch maker or model engineer with a lathe to drill the centre of the crown. The stem will be a Tap 9 which is a 1.1mm thread. You'll need a bottom tap as well as the usual taper tap to cut the thread.
Not difficult in engineering terms but booldy annoying after a trip to a usually reputable retailer.
Cheers Neil
You will not get a crown other than the original. It is custom made for this case only.
A generic in a different, but acceptable style is possible, no?
Edited by Ishima
  • Similar Content
    • Haha. You're just in a wicked mood today John 😅
    • Heres my watch of today, a Smith 13'" RY . My missus bought me this for this Valentines day a bargain 14.99 with a reduction, the seller has occasional 20% off offers now and then so it was about 15ish with delivery. I love Smiths and i love bulleye dials, this is my first one. The watch arrived non working as stated and i knew what was inside and what would be against me, but i enjoy a challenge, we dont expect a lot if anything from pin pallet movements. A balance pivot was broken and i didnt have another staff but i did have another RY with a battered dial so i robbed the balance and tweaked it around to make it work apart from that mostly just a good clean and relubrication. Keyless works are pretty rough by design and the crown is a bugger to get in and out with the dial on, the setting lever hits the dial before it releases it, so a little mod is needed to help that along. Major problem was the pins on the lever were quite worn which make the old tg have a snow storm fit. Its a similar read for most pin pallets, these were brass as was the escape wheel. But perseverance is me, i didn't change the pins but i did spend some time dressing and polishing the worn areas which improved the trace a lot with some straightish lines 😅 and a beat error of .5 . Not sure what the lift angle should be on these and i Wasn't in the mood to work it out and who believes timegraphers anyway, but at the default 52° it runs with 260ish full 210 after 24 hours dial down , the verticals rates were pretty much all over place. So lets just put it in it's superlight aluminium case and see what happens. Been wearing it now for 3 weeks and it's consistently losing around 1.5  minutes a week winding each morning i think pretty good for an old pin pallet watch. I just love this dial, thanks wifey heres my Valentine's gift for yer sweetie x
    • I have a PDF below that will help. The problem was the PDF wasn't designed for this purpose it was designed to tell you what size watch you  have. Then it doesn't take into account movements come conceivably in different thicknesses.   watch-ligne-size-chart.pdf
    • That would be something! Which brings me back to;
    • you think you're going to sleep tonight you're not, you're going to ponder the question of what makes you think those of the right parts?
