  • 0
AndyD
 Share
Question
My engagement watch was a Briel, which turns out to have a 0S60 Miyota movement.
I paid goldsmiths to replace the battery, boy what a mistake. When I collected it the crown came off in my hand. Goldsmith said they can't repair!!! They paid me £250.
So this is when I did some research and took the back off the watch. I believe the stem is still in the watch. But I think I can repair by replacing the stem and crown. I still have the crown.
Could some one advise what stem I need and how can I attach the crown, doesn't appear to have a thread but I think it should have. I can get more photos if needed.
Many thanks
  • 0
Strange. Can you provide a picture of the crown. It would be helpful to know if the stem simply came un screwed or snapped off leaving some of the stem left in the crown.
I realise you had a bad experience with one business but I wouldn't completely disregard seeking out the help of another, at least if there's any watch specialists around your area, The watch mainetence/repair work of jewellers, particularly large chain jewellers (like goldsmith's) often leaves a lot to be desired and what's 'impossible' for them is childs-play for someone who is a watch repairman first and foremost.
  • 0
From the first photo I can see part of the stem, I would say its broken off. The button screws on.
Stem from here. https://www.ebay.co.uk/i/253007986837?chn=ps&dispItem=1&adgroupid=13585920426&rlsatarget=aud-133395220866%3Apla-142405555266&abcId=&adtype=pla&merchantid=9391734&poi=&googleloc=9041119&device=c&campaignid=207297426&crdt=0
Photo of how to take the stem out.
  • 0
Excersise extreme delicacy when pressing the stem release. It is very common for people without the proper experience to basically damage that mechanism. You'll need to press on it while gently pulling the remaining piece of stem from inside the case with a pair of tweezers. And the stem may need to be pushed, clicked in to the proper position (fully in) otherwise the stem release leaver wont be there where you're pressing.
Edited by Ishima
  • 0
My thanks to both Oldhippy and Ishima. All responses are excellent.
I think old hippy is correct in that the crown was stressed at some point and does appear to have snapped of. I intend to get some better photos later as per Ishima.
I also take your points Ishima. My experience with Goldsmiths was very emotional as to have a very important watch (emotionally not in terms of £'s value) returned broken was a true shock , the lady on the counter at my local store was near tears and I hadn't said anything. My true concern with Goldsmiths is that if I can research that stem replacement is relatively simple, Goldsmiths should have been able to replace, but I suspect as with most large scale businesses of this type they went for the easy option and gave me money to which I now have a very nice Hamilton Crosswind and the potential to repair my original watch.
Also, looking at the watch removing the remained stem may be a step too far for me as it may not come out easily as there is little if any to grip so I may have to find a repair support locally (not that many around here Tamworth, England) that according to google. I have sourced a stem on ebay for £5 from USA so, if will see where I go.
But again to both Oldhippy and Ishima my thanks for your time. I will post photos later.
thanks
  • 0
Hi all,
Just been emailed the stems info below:-
065.453 - 1800 Length
065.533 - 2400 Length
065.557 - 2400 Length
How do I measure length of stem required?
  • 0
AndyD from your photos, the movement is 0S20 not 0S60. the stem part number for both is 065-453.
Correct, Breil Ducati One has an OS20.
Great looking watch [emoji106]
Sent from my Honor 5c
  • 0
Hi all,
You will need to cut the stem to the right length when you fit it. For this it is better to fit - measure - adjust until it is right rather than to cut to a "spec" length and fit blind. See here for an excellent walk through by Geo.
As for the crown, if it is stainless steel or plated brass your best bet is to use alum to disolve out the remaining stem leaving you with clean threads to fit it to the new stem.
  • 0
great responses, my thanks. Looks like I have a little work to do.
Here's some more images. Notice in the crown it looks like it snapped off leaving the stem head in the crown, but I could be well wrong.
  • 0
The stem end is like any other stem.
That bit I think is part of the crown.
PS - Sorry about the DNA under the crown [emoji33]
PPS - Got the stem from Leosics in the UK.
  • 0
Does not look good, Check if you can find a suitable replacement on Cousins UK or other source.
  • 0
ro63rto
how would you describe this crown? As JDM advises I am trying to search another source.
You will not get a crown other than the original. It is custom made for this case only.
  • 0
If you can't get a new crown you can drill and retap the original one. You'll need to find a watch maker or model engineer with a lathe to drill the centre of the crown. The stem will be a Tap 9 which is a 1.1mm thread. You'll need a bottom tap as well as the usual taper tap to cut the thread.
Not difficult in engineering terms but booldy annoying after a trip to a usually reputable retailer.
Cheers Neil
  • 0
A generic in a different, but acceptable style is possible, no?
Edited by Ishima
  • 0
Doubt it.
Not seen any similar when I lost mine when it fell out.
 Share
  • Similar Content
    • By Domovoy
      Hi friends,
      I have a 1970's Slava Soviet made watch my uncle gifted me when I was 9... I have kept it in mint condition all these years and for some reason I decided to have it serviced.
      I took it to a watch repair shop (had 5 stars) spoke with the employee and specifically asked to have the watch back in the same or better condition, when I got it back 6 weeks later I noticed they had scratched and damaged the bezel and changed the spring (even through I asked to call me incase any part needs to be replaced)
      Now I need to replace the bezel so thats its not chewed up, the factory does not make parts for it and I am distraught as it was in perfect shape and it took someone else to ruin the watch. I only blame myself but it hurts ?
      Please help me find the bezel and get it back to its former self as much as possible.
    • By RNS
      Good day all,
      I'm a recent 30 year retiree and elected to start cleaning some of my older watches that ended up in a box wrapped in a towel.  One in particular, a gift from my grandfather, began working with a new battery but the crystal appears foggy.
      I would appreciate specific instructions for removing the stem/ crown and cleaning the crystal from an 1980 Seiko with the 6030A movement.
      Thank you in advance.
      Regards,
      Rick
    • By Ivan
      Hello all.
      I have a Krieger Gigantium Automatic Watch, but the stem of the crown is broken,
      I am not sure about the movement, I think it is Self-Winding Automatic Swiss Made 25 Jewels ETA, anyone of you know?
      Do you know who or where I can contact  or buy the correct stem?
      Thanks
      Ivan
    • By Max50916
      Hello! The outer part of the rotor on my grandpa's lucien piccard seashark (AS 1580 movement) has come loose. Is there any way to repair this rotor or must it simply be replaced?
