Oldhorologist
Gordi
Greetings from Western Australia.  I am a retired master watchmaker, who loves all aspects of what we do and I hope I can be of some help on this forum.
So far I have found it very interesting and now I have more "time on my hands" for browsing!
Outstanding! It's wonderful to see another experienced pro stop by and share their knowledge, for some of us this website may be the only contact we have with people who really know what they are doing.
Welcome, and enjoy!
Good to see another Western Australian on here, although I'm only a second year student on watch repair.
Are you a member of Master Clock and Watch Makers of Western Australia?
Look forward to reading your posts.
Welcome from me. It is nice to have another experienced senior watchmaker. To those that are new to horology it might be a good idea and explain what a master watchmaker is. My self I’m a retired watch/clock maker.
Hello Gordi,
Welcome from me as well, I have been the recipient of much welcome advice from the pro's on the forum and an increase to the pool of knowledge can only be good for everyone.
Cheers,
Vic
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
