Clock Oiling
Folkvisor
Cause it is that is one of the many reasons why there are so many lubricants about. You never use a thin oil on a clock train. You do use watch oil on a clock with a platform escapement and I would suggest a pocket watch train oil.
The bell doesn't ring very well because the beater dampens the bell when hitting it.
Is there a way to remedy this?
It is called a hammer that hits the bell. Bend the hammer closer to the bell; it is a trial and error until you get it right. If you have the movement out of its case, it will sound different. Cases were designed in a way so the sound of the strike or chime could sound loud and clear to the ear. Modern clock cases are not, the type of wood also plays its part.
Will do. It's called a hammer for orchestral bells too.
The hour chime is a very nice full sound but that hammer seems to hit the chime then immediately drop away.
Between the bell hammer and pendulum length adjustments It keeps me busy. A work in progress.
Thank you for your advice.
This is a sign that the chiming wheels are not in line with the clock chiming mechanism. Is there any way you can take a few photos so I can point out what you need to do. The other thing do you know the type and make of the movement?
  • 2 months later...
Welcome aboard Dave.
Thank you for the post, it's one I've meant to make for a while now.  I too have been using fully synthetic engine oil for lubricating clocks for years now and have had excellent results.  The dregs left left in the new container from one engine oil change will give you enough oil to lubricate many clocks.
    • This set lever seems to working ok unhardened Nickelsilver, might it deform if i leave it that way ?
    • I found this from a while back CS100 seems fine, but at around 500 Vickers it's not quite as hard as "blue" steel, but still harder than annealed. I'd try to find annealed (the post above has a U.K. supplier of small quantities).
    • As an experiment i was thinking of not hardening it to see how it fairs. Now that i have a complete template i could knock up another in half the time if this loses its elasticity. I might play about with a few pieces today to test their bending and spring properties. This was cs 100 the supplier quoted in annealed state, it was nice to work with files so I'm taking it thats its state. What you are looking seems like it would need annealing to work it. This is why i went for this stuff that cuts out that process, it was so easy to work.
    • Showing state of hairspring on receipt, backplate & 'dished' wheel.  Thanks, Nev. Amplitude v. weak - balance wheel turns over arc of only ~20deg. Don't know how to calculate movement rate or safely vibrate balance spring! Meantime I have reduced the 'dishing' & clock no longer runs for more than a few minutes except face down which supports my theory that it was 'dished' as a hack to avoid doing a proper repair.
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes. A search on ebay UK for "spring steel strip cs" finds plenty available in small quantites and thicknesses from 0.1mm up.  But the question is ( @nickelsilver) which "CS" number is best for watch parts ?  Also, from one of the ads : "CARBON SPRING STEEL. SIZE IS METRIC 15.00mm X 0.10mm X 304 MM  CS100 FINISH BRIGHT . HARDENED AND TEMPERD TO 480-530VPN" I've no idea about 480-530VPN. Does that mean it needs annealing before working?       Have you seen this video, he shows how to determine where the indents go ?
