Raketa 2603 Bent Stem
Dissambled my Pobeda/Raketa 2603 movement. Looks like someone blasted it with WD-40? Oil everywhere and on everything. I cleaned it, re-oiled (only gave it one shot of WD-40) just kidding.
The stem is bent right at the crown (see pictures). The stem and crown are functional and I an reluctant to try to either straighten the stem or remove the crown. I don't know if the crown is pressed into the stem or screwed in--can't tell by looking. I know that Cousins UK lists a replacement stem but they have no picture of it.
Does anyone know how the crown is removed?
Can I try to straighten the stem--or will it just snap in half?
Thanks,
That looks more like the crown is bent ? Do you have something to hold the stem with . A  good pin vise or something. Heat the crown a little with a lighter. To soften the loctite.  The simple unscrew it. Can go to straighten the crown or stem but there is a high risk of snapping something . Test it as it could work anyway?
  • 5 months later...
  • Similar Content
    • Never and others. Yes like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it.
    • I dont think mine is. Its an idea to have them all in one place if possible, then a quick screenshot will have them saved. Unless anyone has any other ideas of how to reconnect
    • My email address is in my profile, feel free all to drop me a quick hello.
