Glycine AS 1130. Time flies
I have the above and it has already caused me many headaches. Right now it's running but racing away at about + 2 hours pd. In my albeit limited experience this is usually a hairspring issue, although the gain is very much less than this in most that I've seen, more like 5 -20 minutes even with the reg fully retarded. The Fried book suggests that this may be a mainspring issue, one of the relatively few repairs that I feel competent to do on something that owes me money.
Opinions welcomed (within reason!)
Roy
Assuming that no one has tried using inappropriate parts in the movement before it came to you then the hair spring is by far the most likely candidate. One or two coils sticking together either by magnetism or oil will easily take the rate way beyond the range of the regulator.
here is  my check list for........
WATCH GAINING TIME
Watch not properly cleaned and oiled
oil on hairspring
watch is magnetized
hairspring coils rubbing or sticking together
hairspring rubbing on balance arms
hairspring bent out of true
more than one coil of the hairspring between regulator pins
hairspring pressing against one of the regulator pins
regulator pins bent to close and gripping hairspring
regulator pushed all the way to fast
balance timing screws loose or missing
balance arms bent in.
Not an exhaustive list but I methodically go through each bit until I find something, and if I cant then I pop and see my local smith for his takings on the problem.
Is your Glycine an old WW2 German army issue one? I have one of those and for the last 5 years have been trying to source a dial for it as mine is missing, I missed out on 2 on eBay both NOS, I contacted the seller who said he would contact his man in Switzerland to see if he had any more, but I never heard back from him, so mine sits in the draw awaiting a new dial.
I might possibly try a transfer dial onto an old generic dial and see how that looks until I can find an original dial.
Thanks folks.
Well the hairspring looks to be in reasonable shape. I don't have it in front of me right now. Certainly it's better than some that I have which run far more reliably. It's not significantly magnetised (first thing I checked). I doused the hairspring in lighter fuel and blew it dry - a quick and dirty fix which has often been successful in the short term. Running fast has usually maxed out at 15 minutes a day and more often less  than that - I've got lots of sick watches so it's probably a decent sample.
I bought this one for resale with a graunched stem screw (replaced) and a consequently disfigured barrel bridge - I have a replacement but don't think it's worth using it. Cleaning the setting gear and stem enabled me to wind and set the watch as properly (which I thought would be all that it needed.)
These only seem to fetch a maximum of £200 as "fully serviced", and then from, er, questionable locations. Looks like a money loser. I'm good at that! Although I recently massaged and sold a "junk" Minerva with an AS movement running well for about £275.
Mine's got a very good dial and a heavily worn case - which actually looks quite nice. I understand (from the Ranfft site) that this movement only acquired shockproofing well after the war which makes mine a replacement - it's pretty clean as a consequence of the dust cap though.
In my limited experience I'f found that trashed detent screws usually herald bigger problems.
What's the likelihood that Mr. Fried's suggestion of a "set" mainspring may be correct? I can deal with that.
Roy
    • in general this shouldn't be any change. but in general questions like this it be nice to know the specifics of the watch in other words how was it performing before it was cased up and what is it doing now.
    • just as a reminder this watch is a Swatch group product. This will bring up a problem like spare parts and technical information. that I found some links to some information on when I talk about your watch and some of the technical and basically your watch is equivalent to 2834-2 for which I'm attaching the technical sheets. But equivalent does not mean exactly the same you want to do a search on the group for C07 as we discussed this watch before including the technical differences how it's supposed to be regulated and basically because it's watch group there is no parts availability. https://calibercorner.com/eta-caliber-c07-xxx/   https://www.chrono24.com/magazine/eta-movements-from-the-2824-2-to-the-powermatic-80-p_80840/ https://www.watchuseek.com/threads/h-10-movement-details.4636991/ eta CT_2834-2_FDE_481857_15.pdf
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
