Broken fixed pin link ?
Hi new here so a big Hellow to you all and hopefully I can get enough advice to help me get my sons watch fixed !!! the watch is a Scuderia ferrari 2 tone s/s watch strap / black face. cut a long story short the watch was dropped from the fifth floor level off our hotel in Ibiza a few weeks back ! anyway found the watch which had only a snapped strap and the second hand had stopped working. so okay looking at the strap I thought it would be a simple case off removing a link ( broken one ) and just having the strap slightly shorter which would not have been a problem , unfortunately the link that broke was was one off the non removable ones on the strap ie fixed pin type. the pins have snapped so they are flush within the sides off the link and so cant be pulled out.. what now ? is there any way off removing these broken fixed pins ?
any help / advice would be very much appreciatted.
Pics are required for help. The biggest issue is the watch has stopped & this should be the first issue to be addressed. If the strap can not be fixed a new one should not be to difficult to source and fit.
Thanks for the welcome guys, okay pics attached. in answer to the last reply can live with the second hand not sweeping, the hour / minute hands are working fine which I am okay about considering we thought the watch was going to be in several pieces / smashed screen etc !!  could replace the strap just wondered if there was a way off keeping the original and removing this fixed pin link ?
Okay thanks watch is no longer made so guess its just acase off getting a similiar size / style strap !
pity I thought there may have been a tool that would remove the broken pins but guess they may be in there for good !!
If the watch isn't running properly, there is no point in fixing the bracelet. Do you know what movement (miyota, rhonda, ETA) is inside? The best bet is to replace it. One can be ordered from any watch parts house for about $20. If you really must try to fix the bracalet, You will have to find a few donor links. The short piece can be removed from the lug and then you'd have to remove two pieces from the long end. It might be easier to simply replace the bracelet with a similar one.
JC
Sent from my SM-G925T using Tapatalk
The bracelet looks like an easy repair to me. Use bracelet pliers or a hammer and a pin punch to drive the broken pin from the narrow part of the broken link. Then find a sting bar to replace the pin. You may need to drill out the hole to take the spring bar. Ensure there is no debris in the larger part of the link. With a spring bar fitted in the narrow part, depress the spring bar ends and manoeuvre into the larger part. This may take patience and bionic fingers.
Cheers Neil
Cheers Neil
That's no easy fix, then! [emoji375]
Nothing difficult in what I suggested. 10-15 minutes work.
Or were you being ironic?
Ironic. Since he is new to the forum, I don't think @jono400 has those tools (bracelet pliers, extra spring bar, dremel drill with microbit, etc), so it wouldn't be any easy fix without them.
J
Hi again guys sorry not been around to acknowledge all your kind replies but again a big thank you anyway. do have one off those cheap Chinese watch strap repair kits so got the basic tools.
noirrac1j - Thank also for your kind advice, sorry not sure if I am following you correctly ?! the broken pin is still within both ends off the strap ie. there is a small length left in each side plus the bit in the centre on the other side off the strap, appreciate I could knock or dremel the centre pin out but not sure how I would go about getting the two other broken bits out as obviously there is no where for them to go by using the punch on these ? would a Dremel with micropunch Break up the two bits off pin remaking enough to replace with the new spring pin ? as I say they have broken flush so no pliers or whatever would be able to pull them out . sorry as a newcomer possibly missing something obvious to which I appoligies ??!!
Hello Jono,
I think this isn't such an easy repair, but you can try to drill through the link with the two broken plugs with a small drill bit...the problem will be that the material is stainless steel and the drill bit may get hot and break before the hole is drilled. After that, use a slightly larger drill bit to drill through the other link and get a small spring bar with the ends that are same size as the holes....after that you have to try to squeeze the spring bar ends in place.
J
P.S.
http://watchfix.info/Bracelet Repairs/Drilling Pins Out.php
Edited by noirrac1j
My apologies. I regard myself as an inexperienced beginner, especially when I read of the heroic deeds of others posting on here. But I must have learned a few things and gained a few tools along the way.
From your last explanation, Jono, it's not such an easy repair. The pieces of the pin still lodged in the out part of the link were probably pressed in an the ends polished flat. You may be able to punch these out. But it's getting to be a lot of work for a bracelet not worth much. On the other hand it's good practice!
Good luck whatever you decide.
Cheers Neil
Hi guys will with your help keep at this just a bit longer before replacing the strap ! okay have now cut thru the last link and removed what was left which as you will see from the picture leaves two protruding pins one each side, tried carefully pulling on the pins with plyers but neither side was  for moving so instead off keeping at it and no doubt snapping one off the pins and being back to square one again !! I thought Iwould stop and see if there was any suggestions on here on what could possibly be used to remove the remainder off each pin ? would some sort off oil loosen the pins to make extraction easier ?
cheers,
john
Okay thanks appreciatte your reply, unfortunately we are talking about one off the fixed / secured links not one off the push in / push out type that are on the majority off the strap ( there is no hole at the side off the strap like the other links to simply push out the pin   ) as I say in an ideal world would simply pull out the remaining pin on each side with plyers unfortunately it does not want to easily come out and again dont want to risk snapping one off the pins taking me back to square one again !!
just wondered if anyone had sucusfully managed to remove a fixed link pin broken like my picture above ?
The hole is there, but covered with a polished cap. Removing it and/or the pin stumps may be indeed quite difficult, e.g. fabricating special tools, drilling, etc. If you like the watch much I suggest you consider wearing it with a strap.
Edited by jdm
Here's a tip that sometimes works.
Put the watch somewhere cool for an hour or so- not the fridge just noticeably less than room temperature.
Then breathe gently on the area where the end of the pin must be. Because the pin and the bracelet are different pieces of metal the condensation pattern will be different (if it works!)
Mark the centre of the pin with a centre punch or a hardened nail. Then you have a chance of driving or drilling out the pin.
If that fails at least you now know how to tell where pieces of metal are joined. Amaze your friends and treat yourself to a new watch.
[emoji41][emoji851][emoji41]
Sorry guys been away for a while and away from computer. again appreciate the continuing replies. unfortunately still no joy with removing the pins. guess it's a new strap, pity as honestly thought I would have got it in the end ??!!
    • See, what has happen is a normal consequece of the reducing the hammer size and changing it's shape by the removing metal from it. But here the hammer is adjustable and just adjustment is needed to correct, and this is what You have done. There is a rule for the adjustment and it is that the hammer must lay firmly on the seconds counter heart and there should be a litle free play in the same time of the minutes counter heart/hammer which alows counter movement of about 0.5 min on the small dial hand (+/- 0.25). Of course, there is no way to make one hammer to delay from the other, as they are one single part. What has changed too is the slope of the hammer head and thus the orientation of the heart has changed, and thus the switching finger position. This led to need of the finger position correction. The rule here is that switching of the minute counter has to start when the seconds counter hand is on '59'. Of course, the seconds hand must be positioned as so the resetting is at '0' exactly. If switching is earlier than 59, there will be no problem, but it will be wrong as reading can be not correct. If the switching starts later, the problems that You described can happen.
    • Thanks, This watch was in a box of old scrape units that a friend gave me. They used to be his late father's who was a watchmaker before the war and then continued later in life. I picked this one out as it looked like it had potential, and I liked the dial, it's been a bit of a learning curve for a beginner but I was determined to get it going. Now I'm on the final lap it feels good. I'm just wondering whether to invest in a decent set of hand placement tools or stick with the cheap Chinese red thing I have, decisions decision 😆
    • An update, for everyone who contributed advice, and for those who come after with a similar problem. Based on the answers received, I decided to work on the face of the hammer first. I used a square degussit stone to guarantee a vertical surface to work against, and ground the face back until it was square across 90% of the depth. I was conscious of the risk of removing too much material.* After I'd got the shape how I wanted it, I polished the surface with lapping film. To cut a long story short, it did the trick and the hammer hasn't slipped off the cam since. Of course, that wasn't the end of my problems. Have a look at this video and tell me what you think is wrong. https://youtu.be/sgAUMIPaw98 The first four attempts show (0 to 34 sec.) the chrono seconds hand jumping forwards, the next two attempts (35 to 47 sec.) seem "normal", then on the seventh attempt (48 to 54 sec.) the seconds hand jumps to 5 sec. and the minute counter jumps to 1. The rest of the video just shows repeats of these three variants. I solved it by rotating the minute counter finger on the chronograph (seconds) runner relative to the cam.  I'd be interested to hear your opinions on that. It seemed to be the right thing to do, but maybe I've introduced another problem I'm not aware of. * What is the correct relationship between the two hammers and cams, by the way? Should both hammers strike the cams exactly at the same time, or is it correct for the minute counter hammer to be a bit behind the seconds hammer? In this picture, I removed the adjusting screw at 1, and the hammers are contacting the cams simultaneously at 3 and 4. I had to turn the screw down tight to achieve this condition after stoning the seconds hammer and replacing the bridge.
    • It was easy enough to pop off. Once I had the cannon pinion hanging on the blades of the stump, I got my #2 tweezers on the gear attached to the staff and levered it down. That way none of the force was on the brass wheel itself.   I reinstalled it and the bridge, and it looks like a small but reasonable amount of end shake. It also spins easily with a blower. It stops quickly, but I think that's due to the large shoulder and about what I'd expect from this wheel.
    • Oh, right. For some reason I was picturing a monocoque case in my head. Good looking watch!
