Summer project.
I love mechanical things, not least the watches, clocks and other mechanical hardware. To be able to repair watches have been a wish in a really long time. Unfortunately I have not had a real place to practice and must recognize that doing it in the kitchen just cannot be reconciled with the family.
That is why I am now going to remodel our 70 's garage into a workshop and hobby room for joy for me and the rest of the family. It is anyway too small for a modern car.
The garage is at about 6.8 x 3 m. and there for approx. 20 square meters. The redevelopment will be extensive as i have to make heating and floor heating window and a small kitchenette. I am now almost finished clearing out the garage so that the work can begin. I will put up some pictures every now and then as the project progresses!
try to get a window facing the sun rise.  have fun.  vinn
Unfortunately it is not possible right now. In the first place, I get a window to the West, later perhaps a narrow one facing north! Over time maybe a towards the East!
No reports from me for a long time but next week my family is leaving for a week and i will be back in business. Lots of plans including finishing a 1972 München pin lever watch (new baalnce turned), servicing some watches (Vostok Komandirskie, Ricoh auto, HMT maybe...), some enameling experiments, making some tools (faceplate for mainplate and case turning) and.... designing my own brand :)
At the weekend i continued to work in the workshop. The load-bearing beams hase been attacked by boring beetles. If they are still active or not is hard to see, so I chose to smear with a means to be sure they are not coming back. 7.5 liters "PROTOX INSEKT" has come on with a brush. I have also created wind screen between the beams so that it does not blow into the insulation when it comes up. Today i started on the electrical installations in the ceiling, among other outlets for powering LED panels!
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
