Seagull movement repair
In many cases Chinese mov.t can't be repaired becase lack of spare parts. And professional often refuse to work on them for this reason and few more. Unfortunately in yhid case the original Seagull mov.t is quite expensive, so you are not in the best position to have your watch repaired.
Depends what is expensive? A seagull ST2130 cost $92 on ebay. think you can find it cheaper maybe? Compared to a ETA 2824-2 i think it's fairly cheap? A service would cost a lot more then $92?
Yes, it's cheap compared to the overpriced ETA, but expensive compared to an equivalent Seiko or Miyota mechanical, or to most quartz movements.
We don't know if the watch needs repair as the OP said, or just service. Owners of cheap watches can indefinitely postpone the latter, but a repair which costs more than a new watch leaves them with the dilemma.
Edited by jdm
In the past I have simply checked over and replaced with new movements. By explaining the situation to a customer they usually understand.
Maybe as time goes by and more brands use these movements (then watch the price increase!)  A proper after-sales network will be set up allowing for replacing parts.
Theoretically, the ST2130 and the ETA 2824 have parts that are interchangeable, so it shouldn't be to difficult to have it serviced and to have parts replaced... Problem you may have is finding a watchmaker willing to take a chance on servicing it and sourcing parts for a ETA 2824 and "Hoping they fit". A new movement will definitely be a less expensive option, but some folks like to keep their watches all original and service the existing movements.
One thing I think a number of people forget, or don't take into account, is that any mechanical timepiece will need service at some point. And it's not going to be inexpensive. Especially if its done by a trained watchmaker. They have to make a living too!:biggrin:
And, I prefer the term "Less Expensive" watch as opposed to "Cheap" ... And, i would not assume because someone chooses to buy a less expensive timepiece that they automatically choose not to pay to have it properly serviced. Yes, at some point there is a dilemma of paying more for a service than the watch may be worth or just swapping out a movement, but the owner may have an emotional attachment to that watch and may want to keep it as original as possible and in good working order. So they may choose to spend more money than it may be "Worth" to repair or service it..
Sorry for rambling...:unsure:
I couldn't agree more. The vast majority of the watches that I rescue, service, ressurect or whatever are "less expensive" watches picked up at boot sales or from eBay. Things like Sekondas and Caravells which were aimed fair and square at the budget end of the market. It always amuses me when I find a greater number of service marks and codes in these watches than I do in the more expensive examples that come my way.
I think the marks are from the time when mechanical watches were the pretty much the only alternative, and maintaining objects was about 100 times more valued than now. And the other reasons is that they broke more often than the quality ones.
Anyway, the single post count OP appears to have lost interest by now.
Also factor in that there were way more watchmakers about, they were quick and (mostly) good. but their prices had to be super-competitive so it wouldn't have been an expensive proposition to repair a modestly priced watch.
Chinese watches.
Poor quality steel, screws that break and springs that don't. They also rust. Movement spacers made of cheap plastic which did not hold the watch properly.
The poor steel was also present in watch bracelets where the links were stainless steel but the pins were iron resulted in frozen links and caused bracelets to break.
My experience with them was more than 10 years ago but the experience has made me avoid them when I could.
The last one I looked at had a clone Miyota. Quality seemed acceptable to the extent that I was wondering if it was a licensed copy made in China. Not marked Miyota though.
Anilv
Chinese watches.
Always worth to mention for the casual reader that not all Chinese watches and movements are in the same league. For example the leader Seagull makes good movements, both in terms of design and execution, in some cases more expensive than Japanese. However they grade them and keep the best ones for the watches they produce themselves.
And then there are the complete watches and movements that they make for the European brands, legally or not. These are also very good.
Edited by jdm
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
    • Well I put the spa on Gumtree (selling service) to try and sell it as it only needs a recirc pump to get it going. However, it weighs circa 250kg, so there's 4 fairly strong guys, and I would have to remove the sliding door in the room completely to be able to get it out, as well as clearing out a multitude of potted plants and the Alfresco outdoor setting to be able to get it out. Then move nearly everything in the back of the garage to be able to push it through to the front of the house. I would also need to hire furniture skates to be able to shift it around as carrying it is out of the question. Then someone would need a trailer to get it to their place as you won't get it on the back of a ute. So, the only answer is, out with the reciprocating saw and cut it all up into manageable pieces. Crying shame as it is in really good nick. I was only asking $1,500 and only got two bites, but it would only take something to go wrong with removing the sliding door etc that everything I make on the sale could go out the door on repairs etc. It would have been nice to be able to turn it into tools etc, but que sera sera. I don't know about the rest of the world, but there just seems to be very little interest from people wanting to buy things secondhand.
