Help with this jewel please
The shock spring rotates and it releases here. However be very carful using peg wood to steady otherwise it will fly away. There is a specific tool that can be purchased for this job or you can make one with peg wood. The jewel then can be removed for cleaning using Rodico.
Kef shock spring tool:
https://www.cousinsuk.com/product/kif-shockspring-tool
58fee8cedbc5a_ScreenShot2017-04-25at07_08_00.png.a0b3191e51dea13cce0ba507ca274a14.png
The lubrication you require is Moebius 9010. There are lots of vids on YouTube re-lubrication of watch jewels Mark has many showing the procedure. However found this that deals specifically with the shock jewels.
Wonderful. I very much appreciate the help you guys so willingly give. Thank you very much
Kind regards
Looks like a shok jewel on russian movement . Vostok maybe?
Oh my word. Spot on it is! You certainly know your movements. I Han spent all this evening thoroughly painstakingly cleaning all the parts with lighter fuel and rinsing in alcohol. Now in going to resEarch correct lubrication before I reassemble again. The last 2 jewels I plan to lubricate are the top and bottom balance wheel jewels.
Does anyone have a schedule or diagram showing the lube points for a Vostok movement please?
Kind regards
No, those screws hold the entire antishock assembly - only take them out if there is dirt in there
Before reading you reply - I took out the 2 screws and removed the whole assembly. Will reassembly be awkward now?
  • 1 year later...
Kind regards
2
Please see the links below. They aren't official diagrams but still useful. The following paragraph is basically a bit advice to any future readers new to watch repairing (so nothing personal).
You can service it like any other mechanical watch. If you want or need a truly great watch servicing course I do recommend watchrepairlessons.com. It contains everything (and a lot more) of what you need to know. I started out without the course and serviced several Vostok 24XX movements using the service notes found in the below links. However, without the proper training that I later got from watchrepairlessons.com, I really can't say I that I did a very good job, among other things, over oiling and doing things in a less than optimal way.
http://forums.watchuseek.com/f54/vostok-caliber-2414-service-notes-very-long-many-pics-226237.html
http://forums.watchuseek.com/f54/vostok-2416b-service-notes-240805.html
Edited by VWatchie
  • 8 months later...
On 4/24/2017 at 11:09 PM, Deggsie said:
Could I kindly ask for advice on how to disassemble, clean, oil and safely reassemble this type of jewel please. The movement is a sekonda
Thank you in advance folks
That looks very much like a Vostok 24XX movement. In the "Vostok 2409 Service Walkthrough" thread, you'll find all the information you need to handle that type of anti-shock spring.
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
