Help with this jewel please
The shock spring rotates and it releases here. However be very carful using peg wood to steady otherwise it will fly away. There is a specific tool that can be purchased for this job or you can make one with peg wood. The jewel then can be removed for cleaning using Rodico.
Kef shock spring tool:
https://www.cousinsuk.com/product/kif-shockspring-tool
58fee8cedbc5a_ScreenShot2017-04-25at07_08_00.png.a0b3191e51dea13cce0ba507ca274a14.png
The lubrication you require is Moebius 9010. There are lots of vids on YouTube re-lubrication of watch jewels Mark has many showing the procedure. However found this that deals specifically with the shock jewels.
Wonderful. I very much appreciate the help you guys so willingly give. Thank you very much
Kind regards
Looks like a shok jewel on russian movement . Vostok maybe?
Oh my word. Spot on it is! You certainly know your movements. I Han spent all this evening thoroughly painstakingly cleaning all the parts with lighter fuel and rinsing in alcohol. Now in going to resEarch correct lubrication before I reassemble again. The last 2 jewels I plan to lubricate are the top and bottom balance wheel jewels.
Does anyone have a schedule or diagram showing the lube points for a Vostok movement please?
Kind regards
No, those screws hold the entire antishock assembly - only take them out if there is dirt in there
Before reading you reply - I took out the 2 screws and removed the whole assembly. Will reassembly be awkward now?
  • 1 year later...
Kind regards
2
Please see the links below. They aren't official diagrams but still useful. The following paragraph is basically a bit advice to any future readers new to watch repairing (so nothing personal).
You can service it like any other mechanical watch. If you want or need a truly great watch servicing course I do recommend watchrepairlessons.com. It contains everything (and a lot more) of what you need to know. I started out without the course and serviced several Vostok 24XX movements using the service notes found in the below links. However, without the proper training that I later got from watchrepairlessons.com, I really can't say I that I did a very good job, among other things, over oiling and doing things in a less than optimal way.
http://forums.watchuseek.com/f54/vostok-caliber-2414-service-notes-very-long-many-pics-226237.html
http://forums.watchuseek.com/f54/vostok-2416b-service-notes-240805.html
Edited by VWatchie
  • 8 months later...
On 4/24/2017 at 11:09 PM, Deggsie said:
Could I kindly ask for advice on how to disassemble, clean, oil and safely reassemble this type of jewel please. The movement is a sekonda
Thank you in advance folks
That looks very much like a Vostok 24XX movement. In the "Vostok 2409 Service Walkthrough" thread, you'll find all the information you need to handle that type of anti-shock spring.
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • Yeah, I saw that in the tech sheet but I don't see how it can be adequately cleaned with the friction pinion still in place. I've accidentally pulled the arbor right out of the wheel once when I used a presto tool to try and remove it. Mark shows how he does it with the Platax tool. Those are a little too pricey for me so I got one of these from Aliexpress and I just push down on the arbor with the end of my brass tweezers. That usually gets it most of the way out and then I just grab the wheel with one hand the and the friction pinion with the other and gently rotate them until it pops off. Probably not the best way but it's seemed to work for me so far.
    • Thanks, Jon Sounds like a plan. Obviously I'll have the face on so do you think gripping with the holder will create any problems, but I will check in the morning to see how feasible it is but I assume it only needs to be lightly held. As for holding the movement instead of the holder won't be possible in this scenario as one hand will be puling on the stem while the other pushes the spring down. That was my initial concern is how the hell can I do this with only one pair of hands. All the other times I've had to remove the stem hasn't been a problem, apart from the force required to release the stem from the setting lever, but now I need to fit the face and hands its sent me into panic mode. If it had the screw type release things would be a lot simpler but that's life 😀   Another thing I will need to consider is once the dial and hands are fitted and the movement is sitting in the case I will need to turn it over to put the case screws in. I saw a vid on Wristwatch revival where he lightly fitted the crystal and bezel so he could turn it over, is this the only option or is there another method?
    • Hi Jon, do You think that relation spring torque - amplitude is linear? I would rather guess that the amplitude should be proportional to the square of the torque. I had once idea to check it, but still haven't.
