Pig nose or snake eyes or spanner driver help
Danh
Hi guys
looking for someone to point me in the direction of tools.
i can not find the sizes of the pig nose screw drivers for watches.
i could just be the search terms I am using from the UK
the description would be 2 holes in the screw head
many thanks
dan
4 minutes ago, Danh said:
Hi guys
many thanks
dan
I've never seen screw heads with anything other than slotted screws in Swiss watch movements, although Philips head screws are used in watchcases and Seiko. Maybe this will help?
J
58fb6355702cb_ScreenShot2017-04-22at10_04_26AM.thumb.png.f9b60b108958af6f4c22ca6c84b542f0.png
What is the spacing of the holes Dan?
I don't know where you'll find the "right" tool, but there are a number of options...
Searching for TH3 security screwdriver will get you 3.35mm between the outer edges of the holes. TH4 is 4.45
You could try a pair of mini circlip pliers, or a pair of dividers.
You could make your own - take a sort strip of steel, bend over one end and file a slot then round the edges to make 2 pins. Or if you wanted to take the crude approach, 2 tapered clock pins cut to fit snugly in each hole and a pair of pliers.
  • 1 year later...
13 minutes ago, gill1967 said:
I'm in the same boat, Off to B&Q tomorrow for 0.7mm drill bits, A great bit of advice/ work around.
Since then I have also made / converted a set of needle nose jewellers pliers
I can not remember the movement - sorry
   there are taper pin stock for pocket watch hinges - about 2 inch long.  vin
As StuartBaker104 pointed out a similar thread seems to be going on at two places.
I usually use tweezers to unwind the two hole nut in these movements, but for those who isn't comfortable to do so I just tried out another solution.
Since these nuts appear in movements of different ligne, the distance between the holes will differ. It probably will do between manufacturers too.
The simple solution is to buy a small divider and modify the tips, make the tips flat instead of pointy. This will make them less likely to slipp. Now you have a tool like "one size fits all".
... now why didn't I think of that. By far and away the best suggestion.  Give that man a medal at once. :D
Excellent - the dividers was one of my suggestions above, but pleased to see it works in practice :-).  I'm sure I have some of those somewhere, so I know where I'll be keeping them when I track them down.
    • in general this shouldn't be any change. but in general questions like this it be nice to know the specifics of the watch in other words how was it performing before it was cased up and what is it doing now.
    • just as a reminder this watch is a Swatch group product. This will bring up a problem like spare parts and technical information. that I found some links to some information on when I talk about your watch and some of the technical and basically your watch is equivalent to 2834-2 for which I'm attaching the technical sheets. But equivalent does not mean exactly the same you want to do a search on the group for C07 as we discussed this watch before including the technical differences how it's supposed to be regulated and basically because it's watch group there is no parts availability. https://calibercorner.com/eta-caliber-c07-xxx/   https://www.chrono24.com/magazine/eta-movements-from-the-2824-2-to-the-powermatic-80-p_80840/ https://www.watchuseek.com/threads/h-10-movement-details.4636991/ eta CT_2834-2_FDE_481857_15.pdf
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
