Removing Balance
N00b question but I've seen two recommended methods to remove the balance assembly from the movement, and now I'm confused which is the best / more correct ?
1. is to lift the balance cock and very gently remove it by just holding the cock and making sure as to not snag the balance wheel. so that the wheel hangs on the hair spring, as per Mark's videos. Also when using this method how does one go about flipping it over to lay it in the parts tray, other than very carefully ..
2. is to pick it up by holding the balance cock and wheel together in your tweezers, as per the picture attached (sorry for the blurry mobile phone pic).
So which is the most correct way and more importantly why? Which way should a n00b like myself be using.
I use the second method. As i am elderly i tend to shake a little making the first method difficult.  But that can be risky and i think u can bend the pivot if you hold to tight? On balances that has a jewel that you can remove . I do that and put it back after i have put the balance back on the movement?
I use both methods. I've once tangled a hairspring using method one (balance suddenly sprung upwards due to sticky lower jewel). I've once bent a lower balance pivot using method 2 since the lower pivot was stuck again, and the balance always lifts at an angle when you use this method.
I usually go for method 1, and use method 2 if the balance is sticky. If it is too sticky, then I pick up an oiler in my other hand and use it to persuade the balance wheel to lift.
2 minutes ago, madchops67 said:
I use the first method to avoid damage to the hairspring, just in case it's gets nicked by being compressed against the balance wheel and balance cock.
That can't happen, because the shape of the upper pivot into the balance cock hole the makes so that there is always a certain space between the wheel and balance body.
On the other hand, when you keep the wheel dangling by the hairspring, the latter can get distorted by catching int something, or by the wheel weight itself.
It happened to me once before, maybe because I gripped to hard with the tweezers and the outer part of the spring end up distorted. It may have been pinched or rubbed against the balance cock. That is jus my experience, so that's why I use the first method.
I prefer option 1 but use option 2 if the whim takes me.
I like to lift the cocktail and rotate so it sits on the movement leaving the upper staff pivot loose. Then lift the lower pivot out its jewel. Then lift the assembly. That way you'll not end up with a jumbled mess if sticking pivots in the jewel hole.
On old pocket watches there is a third option.
3. Loosen the stud retaining screw. Push the stud down away from the balance cock. Remove the balance cock. Then remove balance wheel and staff. It can then be reassembled on the worktop.
I'd have to say it depends a bit on the movement.  In some movements the center wheel is very large and will cover a good portion of the balance making option 2 difficult.  Other times, if the movement hasn't been serviced in quite a while or you know the balance pivots may stick, option 1 goes out the door.
I generally use the first option but with a caveat; Once the balance cock is loosed I'll lift it and shift it slightly to release the top pivot from the jewel, then lift the balance wheel up out of the bottom pivot before removing the entire assembly.
If you use method one you don't need to leave the hairspring dangling. I use a balance stand and a bit of rodico and it could sit on its standard for years if necessary. Have attached some pictures for demo. Just remember when taking the balance assembly of the stand to hold the wheel gently incase lower pivot sticks in the rodico. Then release from the rodico.
I think people prefer method 2 to avoid having to flip the wheel over when working on the balance.e1e993a4a39694fe7cc590f463b3bcd3.jpg3082f14a7ea479edbf4eec8d2c605dac.jpgc13f1cabc442e023536908a694af60d7.jpg
Great question ... and answers!
I've always gone for option 2 as it has served me well but I might start using option 1 for some of the reasons given.
And digginstony I am so getting (or making) myself a balance stand! :)
Edited by WatchMaker
I use this method so I can sneak up on it, save for the third method there that I haven't thought of, pretty slick!
BTW I just got one of those balance stands/tacks and it's extremely useful.
What has that to do with this? [emoji4] Better to let it swing?
Yep it's more of a swing than a vertical lift, to move the balance bridge from its fixing stud or studs Then ease the lower pivot from its jewel but it still necessitates a slight lifting motion ??
    • This is a very valid point and a subtlety that I was unaware of until fairly recently, learning all the time, the video below explains this point well:
    • You don't have to use his special tester. Any good multimeter would work.
    • Yes, it looks like GT Revue 30. Doctor, You can not replace escape wheel by the dimensions You listed. One needs to know much more things like number of leaves of the pinion and it's diameter, the position in high of the table and the pinion, the hight between the pivots, the exact pivots diameter... And then, even if suitable wheel is found, one will need to know how to adjust the pallets position correctly. Restoring antique movements is something different than replacing parts. In older movements parts are not interchangeable, this means spare parts do not exist. Here the case is different, but still escapement adjustment will be needed if a wheel from a donor is found. So may be it will be easier to restore the donor for You...Restoring antique movements usually means making of the parts needed and this requires knowlage and working on lathes skill. In this case repivoting of the wheel is the natural solution, but there is a long way that one must walk untill getting ready for such work.
    • I was looking at Essence of Renata, a chemical used a lot for cleaning hairsprings: "Specially prepared solution for degreasing watch and instrument components. Indispensable for degreasing hairsprings." Looking at the MSDS you can see this is just pure n-Heptane, so could be an option for those who don't want to use the chlorocarbons or hexane?     HF6013 - Horological Essence COSHH Safety Data Sheet Horological Essence_0.pdf
