Do you own a ticking bomb ?
wls1971
Whilst doing a bit of research on anniversary clocks I came across a few intresting articles on a Haller clock that through a combination of bad design and wrong use of plastics can literally self destruct on your mantle piece and can cause injury, they where eventually withdrawn from the market, if you have one call bomb disposal:biggrin:
The danger comes from the fact that the mainspring for this 400 day clock is wound onto nylon spools that over time become brittle and can fail at any time releasing all the energy from a reverse wound spring this as earned them the nick name "The german time Bomb"
http://erkelzaar.tsudao.com/models/ultra/german-tb.htm
http://www.anniversaryclockidentification.com/pages/sh-gbt.pdf
  • 1 year later...
Hi All,
I just came across this thread, did not see this one.....I am ashamed to say that this was ME, this was my first and LAST Haller clock!!
I got this from an auction and when I got it home, I could not wait to try it out to see if it worked.. At the time I was only into the restoration of French slate clocks, so this was a new one for me.
I set it up and tried to wind, but it was fully wound, so started the balls going and it worked. I wanted to see that it worked OK before stripping down to clean it, as it was a tad grubby and I like to tinker... After about twenty minutes it stopped, perhaps it needs a drop of oil I thought,..BIG MISTAKE!!! I started to undo the 4 nuts on the backplate, un-be known to me this also held the mainspring in place. what a stupid setup, no warning not to remove.
Well this is how I gave it the name of The German Time Bomb, because it went BOOOM it exploded very loud, and the plastic mainspring wheel after it shot out and broken into lots of pieces, it embedded in my chest, I also got a nasty cut on my hand, I was very lucky, if that had hit me in the eye, I dread to think what would have happened. The photo doesn't show all the bits of the mainspring, there were lots!!...Lessons were learnt that day.. Strange I read there was another that exploded on someone's mantlepiece about a week later, this was just sitting there and suddenly went, there was glass everywhere from the dome...My clock went in the dustbin never to be seen again.. I remember later I put the dome off mine on ebay and got more for that than I paid for the clock!!
As I said lesson learned!!!!!!
I will stick to my French and carriage clocks, a little safer!!
Len
I have serviced/repaired Haller's in the past but not that particular calibre.However the absolute rule with clocks is ALWAYS remove the power before stripping a clock. The springs on clocks are powerful and if let loose uncontrollably they can not only destroy a movement but cause serious damage to yourself.
Great advice to the newbie..Too late for some..Like myself...lol
    • Haha. You're just in a wicked mood today John 😅
    • Heres my watch of today, a Smith 13'" RY . My missus bought me this for this Valentines day a bargain 14.99 with a reduction, the seller has occasional 20% off offers now and then so it was about 15ish with delivery. I love Smiths and i love bulleye dials, this is my first one. The watch arrived non working as stated and i knew what was inside and what would be against me, but i enjoy a challenge, we dont expect a lot if anything from pin pallet movements. A balance pivot was broken and i didnt have another staff but i did have another RY with a battered dial so i robbed the balance and tweaked it around to make it work apart from that mostly just a good clean and relubrication. Keyless works are pretty rough by design and the crown is a bugger to get in and out with the dial on, the setting lever hits the dial before it releases it, so a little mod is needed to help that along. Major problem was the pins on the lever were quite worn which make the old tg have a snow storm fit. Its a similar read for most pin pallets, these were brass as was the escape wheel. But perseverance is me, i didn't change the pins but i did spend some time dressing and polishing the worn areas which improved the trace a lot with some straightish lines 😅 and a beat error of .5 . Not sure what the lift angle should be on these and i Wasn't in the mood to work it out and who believes timegraphers anyway, but at the default 52° it runs with 260ish full 210 after 24 hours dial down , the verticals rates were pretty much all over place. So lets just put it in it's superlight aluminium case and see what happens. Been wearing it now for 3 weeks and it's consistently losing around 1.5  minutes a week winding each morning i think pretty good for an old pin pallet watch. I just love this dial, thanks wifey heres my Valentine's gift for yer sweetie x
    • I have a PDF below that will help. The problem was the PDF wasn't designed for this purpose it was designed to tell you what size watch you  have. Then it doesn't take into account movements come conceivably in different thicknesses.   watch-ligne-size-chart.pdf
    • That would be something! Which brings me back to;
    • you think you're going to sleep tonight you're not, you're going to ponder the question of what makes you think those of the right parts?
