Do you own a ticking bomb ?
wls1971
Whilst doing a bit of research on anniversary clocks I came across a few intresting articles on a Haller clock that through a combination of bad design and wrong use of plastics can literally self destruct on your mantle piece and can cause injury, they where eventually withdrawn from the market, if you have one call bomb disposal:biggrin:
The danger comes from the fact that the mainspring for this 400 day clock is wound onto nylon spools that over time become brittle and can fail at any time releasing all the energy from a reverse wound spring this as earned them the nick name "The german time Bomb"
http://erkelzaar.tsudao.com/models/ultra/german-tb.htm
http://www.anniversaryclockidentification.com/pages/sh-gbt.pdf
  • 1 year later...
Hi All,
I just came across this thread, did not see this one.....I am ashamed to say that this was ME, this was my first and LAST Haller clock!!
I got this from an auction and when I got it home, I could not wait to try it out to see if it worked.. At the time I was only into the restoration of French slate clocks, so this was a new one for me.
I set it up and tried to wind, but it was fully wound, so started the balls going and it worked. I wanted to see that it worked OK before stripping down to clean it, as it was a tad grubby and I like to tinker... After about twenty minutes it stopped, perhaps it needs a drop of oil I thought,..BIG MISTAKE!!! I started to undo the 4 nuts on the backplate, un-be known to me this also held the mainspring in place. what a stupid setup, no warning not to remove.
Well this is how I gave it the name of The German Time Bomb, because it went BOOOM it exploded very loud, and the plastic mainspring wheel after it shot out and broken into lots of pieces, it embedded in my chest, I also got a nasty cut on my hand, I was very lucky, if that had hit me in the eye, I dread to think what would have happened. The photo doesn't show all the bits of the mainspring, there were lots!!...Lessons were learnt that day.. Strange I read there was another that exploded on someone's mantlepiece about a week later, this was just sitting there and suddenly went, there was glass everywhere from the dome...My clock went in the dustbin never to be seen again.. I remember later I put the dome off mine on ebay and got more for that than I paid for the clock!!
As I said lesson learned!!!!!!
I will stick to my French and carriage clocks, a little safer!!
Len
I have serviced/repaired Haller's in the past but not that particular calibre.However the absolute rule with clocks is ALWAYS remove the power before stripping a clock. The springs on clocks are powerful and if let loose uncontrollably they can not only destroy a movement but cause serious damage to yourself.
Great advice to the newbie..Too late for some..Like myself...lol
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
    • Well I put the spa on Gumtree (selling service) to try and sell it as it only needs a recirc pump to get it going. However, it weighs circa 250kg, so there's 4 fairly strong guys, and I would have to remove the sliding door in the room completely to be able to get it out, as well as clearing out a multitude of potted plants and the Alfresco outdoor setting to be able to get it out. Then move nearly everything in the back of the garage to be able to push it through to the front of the house. I would also need to hire furniture skates to be able to shift it around as carrying it is out of the question. Then someone would need a trailer to get it to their place as you won't get it on the back of a ute. So, the only answer is, out with the reciprocating saw and cut it all up into manageable pieces. Crying shame as it is in really good nick. I was only asking $1,500 and only got two bites, but it would only take something to go wrong with removing the sliding door etc that everything I make on the sale could go out the door on repairs etc. It would have been nice to be able to turn it into tools etc, but que sera sera. I don't know about the rest of the world, but there just seems to be very little interest from people wanting to buy things secondhand.
    • I would like to see the movement. The watch is the movement. Anyone can print a name on a dial and sell it as "the maker".
    • Thanks for your answers! There seems to be a contradiction between these two answers, so perhaps I need to clarify. The flat and convex jewels look identical on the side facing away from the pivot shoulder. That is, there is an oil reservoir. I don't know if that changes anything but I thought it was safest to clarify since I didn't include a picture of the jewels from the opposite side.
