Question about BFG 582 and 866 parts for jump hour watch
Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks! -
By joelcarvajal · Posted
Thank you all for the replies! Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal! Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great. I wonder what the cons are? -
Hi Jon, do You think that relation spring torque - amplitude is linear? I would rather guess that the amplitude should be proportional to the square of the torque. I had once idea to check it, but still haven't.
