Pins how many types and is there a chart?
Hi everyone i'm new on this forum , and to the world of horology, so all help & tips are welcome in learning and understanding how to solve some of the problems i come across..   so i apologise in advance if some of the question i will post will seem "childish" to you.
I have a SECTOR no limits Watch ( well known cheap Italian brand ) i decided to open and do a battery change... I found out that who ever serviced it before bent the case pin or at least did not replaced it with a new one as i was told was part of the full service. < Battery replacement, seals replacement and pressure testing >
My issue is finding out what pin it is and where to order one.
I have seen a few types over the net and in a few net shops but none like this.
Is it an exclusive to the make? Can i replace it with another of a different type and witch one would suit best?
Thanks for all help and suggestions...
IMAG3255.thumb.jpg.deeb17eb9fcb0a6ad3fb46182b4c3304.jpgIMAG3254.thumb.jpg.1d5c896dad3a09654fb7cc5c6a7e7621.jpgIMAG3256.thumb.jpg.6f979d22cc7caf1f178c2067b47ef08d.jpg
You can replace it with a split pin or (with the right dies) make the creases in a straight pin.
But in practice in most cases for bracelet pins it's enough to straighten them manually in order to reduce the play.
