Hi from Northants!
Hi, I'm Jason. A 40 something IT Security /  Cryptography expert working for a large UK Bank. I'm happily married with two cats.
Hobbies include my kit-car, my engineering 'workshop' (A shed in the garden which I hope to at some point in the near future start building clocks in), reading large quantities of sci-if, scuba diving (see video) and supporting my local Rugby Union team (come on you Saints!) and following F1. I've also just got a 3D printer, which is great fun (when it works!)
Oh, and of course watches and clocks. I've been steadily acquiring tools so I can start learn the dark arts of Watch repair.
Cheers,
Jason
Welcome Jason there's no such thing as the dark arts and mysticism here you want to know something you ask and your answered no question too small no matter how stupid you may think it is everyone has to learn and this is one of the biggest classrooms on the net when it comes to all things horological.
Have fun
5 minutes ago, dadistic said:
Greetings!
I see you are getting ready for a "deep dive" into watchmaking :)
Hey there !!
Kinda sorta. About a year ago I overhauled a Seiko 7S36, self-teaching myself with info on the web, including WRT.
It turned out well & was a lot of fun, too. This Seiko 6347 I'm working on now needs some TLC, & I just want to be sure I get it right. I think it's the only total mechanical moon phase Seiko ever made, with other styles, of course. Seems to be an oddball, as well. I really like it.
When will you be making the "Deep Dive" ?
Cheers !!
Hello Jason and Welcome,
Sure you will find a good home here.
The garden shed is a thought I toyed with but started overcomplicating it by planning insulation and lining as well as looking into temperature control and consumer unit and other things, may get back to it, perhaps!!  A few members have mentioned 3D printing, sounds fascinating, any good for the new pound coins ;)
Cheers,
Vic
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
