Tweezers advice?
Tcarpilot,
I bought a set of very nice tweezers from an Ebay company called RED ROOSTER UK. I don't know if they still carry the same brand I bought but it might be worth checking them out. At the time I only paid $30.00 for the entire set and they worked great.
david
The brand of tweezers I purchased from Red Rooster UK were called Stella Tweezers. They were very well made and have performed beautifully over the past several years. I also bought a set from Finding King called Moon Tweezers. The Moon tweezers had to be reworked with a sharpening stone in order to get them to work properly but the Stella tweezers worked perfectly right out of the pack. I don't know if Red Rooster still carries that brand or not. The only tweezer I was not able to find a less expensive substitute  for, was the Dumont #5. Other than that the Stella's have worked out just as well as my Dumonts.
david
Most tweezers are designed and manufactured for the medical and dental industries. The angled tips are useful in a restricted work space such as someone's mouth. The world has a lot more doctors and dentists than watchmakers. Some of the tools that watchmakers and jewelers use have been borrowed from other industries.
david
  • 2 months later...
Whilst engaged in another thread a question kept coming to mind but it didn't really belong there. So I'll ask here.
With tweezers do you prefer stainless steel or high quality carbon steel ? Or do people not really care.
My own preference is carbon steel because it will retain its shape well and when "stressed" is easily corrected, which is not the case with stainless
Stainless for disassembly Brass for assembly thats my preference.
I can see why you would do that. Stainless incase something doesn't come out or off the way it should and brass minimising risk of scratches and damaged to tweezers. That's very clever ! I will adopt this myself with my brass tweezers.
Many thanks for your reply
' stressed tweezers !! ' why ? Because in my personal sense, you do not raise a brick or you do not squeeze a piece out of hand? For the sorts of metals concerning the tweezers, I imagine that everyone makes use of what he has provided that they are not magnetised. Finally, if we take care of our tools, I can easily imagine that we should not be forced to twist our tweezers. On the other hand, for screwdrivers, it is different because I saw tons of watchmakers On Youtube that work poorly and do not take the proper size of screwdriver for different screws ... I do not know much about watchmaking but my tools, I take care of it ;)
' stressed tweezers !! ' why ? Because in my personal sense, you do not raise a brick or you do not squeeze a piece out of hand? For the sorts of metals concerning the tweezers, I imagine that everyone makes use of what he has provided that they are not magnetised. Finally, if we take care of our tools, I can easily imagine that we should not be forced to twist our tweezers. On the other hand, for screwdrivers, it is different because I saw tons of watchmakers On Youtube that work poorly and do not take the proper size of screwdriver for different screws ... I do not know much about watchmaking but my tools, I take care of it [emoji6]
In this context it refers to the ability to retain shape under normal and unforseen circumstances.
Cheap steel has no flexibility to return to shape so constant maintenance would be required.
English gunmakers prefer a mild steel (EN21) in their gun barrels! Though this quality steel enjoys a great deal of flexibility to return to shape even when pushed beyond its normal working pressure. Due to faulty ammunition.
German makers tended to use a much harder steel. Though could shatter with fatal consequences when pushed beyond its normal working pressure. This rarely happened .
It's all a question of getting the right balance.
I've used brass and carbon steel exclusively.  The brass tweezers are used about 95% of the time but they require a bit of maintenance since brass is soft and prone to deform.  The carbon steel come in handy for the real precision work but they will scratch parts quite easily and are prone to magnetism.
Eventually I'll expand my kit and probably add a set of stainless tweezers.  I'm hoping there will be a few more people piping in regarding the pros and cons of stainless tweezers in this thread.  :)
Well, now i understand the differences [emoji6]  but but for the watches, no need to stress a tweezers  ....Thanks guys for the reply [emoji6]
You'll find the most experienced watchmaker will need to re-shape (Dress) his tweezers and they apply their craft to this in a most proficient and expert way and is an essential skill that needs to be learnt. [emoji4]
I dress mine every week especially the gripping surfaces I grip a file between the ends and gently move the file this gives the tweezers more grip.
Check this video its very informative.
Edited by Cad101
Love my new Dumont Titanium tweezers? So light. And not that sensitive for bending. Can ping a few screws if you press to hard on them. But once you master that i no problem: Great for working quartz and the don't get magnetic. Bought a 5 and  a 2. Dressed the 5 sharp tip a little as it was like a needle :)
Carbon steel tweezers can be glass-hard. My stainless Dumonts are softer and still get magnetised slightly anyway. I also have their "Dumostar" versions which are very hard, to be fair.
As already mentioned, dressing them is very important, including giving the insides a slightly co**BLEEP** finish to provide grip.
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
    • Now this has happened I bet China or India just to name two will start to produce none genuine parts.  I did. But idiot Boris Johnson failed miserably in his negotiations. The E U stitched up the UK like a kipper. Nigel Farage  offered his help but big head Boris declined. So this is why we are in this mess all because Johnson wasn't clever enough.
    • Hands up all those who voted to leave the EU 😂, oopsie.  UK has just signed the Hague convention, next year that will provide cross border clout to British courts.
    • Ive heard about that oil before for the lever pins. I found it easy to work on , it didn't have a whole lot of pivot wear but i bit sloppy on the lever cock, i think you have to live with what you have or bin it. Stiff to wind and set ?  Not a cannon pinion issue that has no friction thats made up further back and if I remember the barrel drives the hour wheel. No problem on this one .Let me know when you start it as i have another that donated to this one, i can work alongside you with it, two heads are better than one.
