Tweezers advice?
I've been using the Dumoxel #2 and #5 mainly (I lean towards #5 mostly) but I've seen Mark's tweezers in the videos and they look mighty good and strong....Since my #2's are a little battered I was wondering what were the one's featured in the videos.
I'm also open to opinions and suggestions as to what will be a durable and worthy replacements to the above 2.
Your input is deeply appreciated!
Robert
If you're handling delicate steel parts, brass tweezers are safer because they're softer than steel and won't mark the components.
Thanks Will,
I'm not too concerned about damaging surfaces presently but then again, once I actually start turning screws and loosing springs, etc., that may change :)
I'll leave them on my "nice to have" list for now.
Rossco
By now, everyone knows I'm working mainly on Seikos -- apart from the rare Unitas 6498 or the ETA 2801-2/2824/46-2 mostly on the waiting list -- and so there is a question that has been bothering me for quite a while (but don't want to risk $40 plus replacement waiting in this experiment).
The barrel and train wheel bridge in the Seiko 7S26 or 7S36 has a clip that holds together the first reduction wheel and the pawl lever (magic lever) together. In the service data, they attach and/or detach the said clip, or "reduction wheel holder" as they call it, with tweezers.
After a while I guess you get the hang of it and do it in one swift movement -- at the beginning it takes more tries!. Either way, there is potential to leave marks on the bridge due to the action of the tweezers in this operation. (I have!)
The question here would be: Will brass tweezers be strong enough for this task (without the tweezers being damaged)?
FYI,
Those of you guys in the USA looking for some very nice Brass Tweezers, Dashto Horological has some Very nice 1-AM Dumont Brass Tweezers for $7(retail is roughly $30us). I bought a pair and was very surprised to find they are brand new! I had to slightly dress the tips, but now they are perfect! I use them for quite a bit for assembly work....
The website is listed here...
http://www.watchrepairtalk.com/topic/169-united-states/
Part number is:
009.3131
  • 4 months later...
I have many tweezers however its taken me a while to get the handling and the care correct,
Would like to start again afresh with a new set. Need some that i will reserve for hairspring work as well.
Thanks in advance
Jonathan
Hi Jonathan,
for hairspring work it is recommended very fine tweezers: #4 and #5 are preferred. I know good ones are expensive but they are a sure shot and the material is better. Cheap ones, well, you get what you pay for but some may come out all right momentarily if you know how to prepare/dress them correctly. A new set would include a #1, 2 #2s and 2 #5s and a #3 and maybe a #4 and #7 (if you feel confortable with the "beak" type).
I personally favor #5 for everything, but keep a #2 handy for heavy stuff. I got 2 types of #2, a wide point one and a fine point one, they each serve their purpose.
I think the last cheapo tweezers I got to experiment with and after dressing them right were quite acceptable -- but needed constant re dressing -- were "Stella" or something like that. In any case, ofrei has some cheap Chinese ones that are comparable to those cheap ones.
Hope this helps,
Bob
I have had many brands of Tweezers over the years and always keep coming back to Dumont.
Size 5 or 4 for hairspring work.
Size 2 For general work.
I personally have no use for any other size apart 5, 2 and from my brass tweezers which are around size 3.
Hi all,
I have one good pair of quality brass tweezers, which are Bergeon gold plated, pattern 1AM and definitely on the pricey side. The other two pairs I have are cheap, Indian made and are a mess. I'm using them to practice dressing tweezers. Anyway, there doesn't seem to be anywhere near the availability of quality brass tweezers as steel. Which brand/pattern do you recommend and does anyone know a good supplier for them on the U.S. side of the pond?
Thanks in advance.
Hi Don,
That's a good question, I've been searching high and low for some brass Dumond tweezers. Ofrei used to have them and now they are gone. Only ones available are Bergeon...The indian/chinese/whatever I got are not exactly doing too well even with dressed tips. So, I'm hoping a source for those arises soon on our side of the pond!
Cheers,
Bob
I have a pair of the Vetus AA brass tweezers which got from Cousins last summer for a few quid. They seem pretty good to me but took a little getting used to as I prefer to use the Dumont No4 pattern tweezers which a quite a bit finer.
 Maybe there is'nt a brass tweezer other than the AA model from Vetus . To bad . There are also carbon tipped tweezers ?
Hey Bob. If you're interested, I found a couple of sources for the Peer-Vigor brass tweezers in the U.S.
http://portlandjewelrysupplies.com/sitetools/product.php/view/detail/id/5082
https://www.artcotools.com/tweezers-patterns-aa-rr.html
Shipping is to expensive for me unless I'm buying more items, but they're bookmarked for later use.
    • Getting back to the issue which is us guys repairing or just enjoying horological exploits. The big worry now is how sound is Cousins as company going forward. The of cost if this 8 year legal battle will be astronomical. Cut backs will happen noticed already how the Cousins catalogue is half its size this year. The main supplier going out of business will hit the UK horological community in a big way.    On the Brexit issue it was about a sovereign country being able to make its own laws and trade with any country in the world. I cannot see what was wrong with this. For those who wish to re join the cost would be very high indeed.
    • Yes, it's the same (old) song and it's getting worse & worse;
    • 🤔 leaving the EU meant that UK was no longer part of the convention and have already been turned down an independent reapplication. I'm pretty sure courts have to be held in Switzerland in this case. There will be a lot more watches stashed away in draws  tbh, folk wont be able to afford to maintain them. Cheap watches will be bought and top end watches by folk with plenty of cash that can pay for service and repair. The expensive once in a lifetime gifts and everything else inbetween will be at the forgotton when they stop working. I know i was being a numpty, get used to it 😄 Anybody that knows will boycott them, but besides repairers who will know. Nope will never buy one, i made that decision as soon as i learnt about this.
    • although not in this case.  It was the Lugano Convention and its deficiencies that allowed a Swiss court decision in the first place.  This isnt really a Brexit issue at all.  A decision that affects both the EU and the UK should never have been heard in Switzerland. I bet the authorised service centres in the UK are pretty pleased.  It's a massive shame, though; I believe watch owners should be able to choose to have their watch serviced by whoever they trust.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
