Battery for a ESA 942.711 lcd watch
18 hours ago, Tiktok said:
If it's the one that takes 2 batteries I think they are size 392
Ordered. Fingers crossed that it will work :)
Maybe it should be ETA 942.711 as i didn't find anything on ESA ?
Edited by rogart63
On 30/3/2017 at 9:00 PM, Tiktok said:
SR41 is a 392 battery as in picture, remember to put them in the correct way as in picture.
I just put esa 942 711 into google images to get picture.
The seller told me had tested the watch with some batteries. He said it didn't work.Can hope he did set them the wrong way. And when i put them in the right :) Let there be light. If not i have a NOS i can buy.
Maybe i should take a look under the circuit tomorrow. Before i smack the batteries in.
Edited by jdm
Please do quote pictures
Hope he hasn't put them wrong way and blown the circuit!!
:( didn't work? But watch watch nice. So i will try to find a new circuit for it. The lcd was working but lots of numbers was missing. Tried to clean the strips on the lcd screen but didn't help. Or a complete movement will be better?
  • 1 year later...
Sorry to bring up an old thread. Did you end up getting it all sorted?
Yepp .  I got an other movement from the guy i bought a movement from. It's even out of the building. Sold it to a collector of Certina Chronoolympic watches.
Great stuff. Iv'e got a Longines one that isn't working either. Thought it might of been an easy fix until I removed the black plastic cover and saw this...
  • Sad 1
Maybe you could try using conductive paint on that? Have you tried to clean it with isopropanol?
I have cleaned it up and Iv'e used conductive paint to to re do the corroded parts, with no luck :unsure: I hope its not the IC (Think that's what it's called) I will start a new thread about it.
    • Hi. Yes I get it , the slot in the end I’d to allow you to screw the button on whilst holding the pusher shaft. To remove the pusher tube you will need a tool such as the one shown by Richard. I think Ali Express the Chinese Amazon has replicas of the Horotec system for a lot less money, how effective they are not having had to use one. But as you said the way to go is complete removal and replacement, bodging it up will  lead to a repeat failure
    • It does look like it seems to be working again I'm getting emails.
    • One of the things that I've been bothered with lately is timekeeping? For instance a 90-year-old pocket watch what so to timekeeping was it supposed to keep? They publish railroad timekeeping but I don't know how well normal non-railroad watches were supposed to keep time. The reason why the question comes up for me is I spend a lot of time at work adjusting watches to keep really really good time  because I have to please my boss where as when the watch was made I have to wonder what kind timekeeping would've been acceptable. After all they typically didn't have timing machines 100 years ago and they were timing and six positions certainly not for the non-railroad grade watch. On the other hand I do get paid by the hour so maybe I shouldn't be concerned of how much time I Spend trying to make everything keep chronometer timekeeping almost. Citing a Delta of 40 seconds for a 90-year-old watch is quite outstanding.
    • That's an interesting question which I don't think I've seen explained anywhere. But I think the problem will go away just about instantaneously. In other words the  coating is really thin and it should go away almost immediately. So the problem should resolve itself extremely fast.
    • I experienced that different types of shellac and their ages are affected differently by IPA. Sometimes the shellac dissolves in a few seconds and sometimes several minutes are required. Nowadays I never let shellac come into contact with IPA. It's a hotly debated topic here on WRT if you search. Like John, I don't think you need to worry about the weight of the shellac, but instead that it might start rubbing against something. When I learned how to adjust pallet stones, I tried documenting my experiences in this thread. Hopefully, it can help you. I personally don't believe in the idea of abrading the epilame before oiling so I don't think you need to think or worry about it. The only time I've heard anyone mention this is Alex on the YouTube channel Watch Repair Tutorials but actually no one else. I'm not saying it's "wrong" just that I don't think it's necessary or adds anything.
