Which one would you like and why
oldhippy
Id go for the second of the two good quality french movement in a interesting case, the Angelus is a modern clock produced I would say sometime in the last 30 years and although Angelus being regarded as a good maker it lack's the quality of the second of the two it is definetley not a antique clock.
2nd one because it's cheaper :)  Neither are very old I suspect (they both say "made in"... which to me in a hint). I wouldn't buy either of those.
The first one looks modern, no natural corrosion anywhere.
The second one has 2 different styles of hands, some clearly replaced parts, looks a bit older..,
the Angelus looks like a fairly modern reproduction no discoloration of the enamel dial also the brass shows no sign of tarnishing.The second clock shows lots of age discoloration and the hands on the dial are not a matching pair. But ideally, you need to look in person to see the movement to know for sure.
It would be the second one for me, battle scars and all.  Whether the parts are correct for the case I don't know, but to me it is an old movement, pinned together and has a look of elderly quality.  A bit like yourself OH! :)
PS The pendulum has 3606 lightly scribed onto it which appears to match the number on the movement.  This probably indicates it's original to the clock.
The correct name for these original clocks is French Four Glass Clocks. Most come with a mercury compensated pendulum this means the effect of the weather will not affect the time keeping. Many have visible escapements. They come in various cases from very plain to extremely decretive and can be quite valuable. Most movements are striking on a gong or bell, although I have come across Timepieces.  I have included a photo of a nice decretive one so you can see what I mean. They would have been made from around the 1860 to about 1913 certainly not in or after WW1. Correct about the pendulum it should have the same number as the movement.
The Angelus is a modern clock and it has a bim bam movement or ting tang, two bells and two hammers and has little resemblance to the original apart from the shape of the case, it even has those terrible clips to hold parts on such as the clip holding the bell in place.
It would be the second one for me no hesitation at all.
Thanks to all for taking part.
Late in replying, but I'm please to say I would of gone with the second one too, the screw on hands, nasty C clip and the general 'not old' look of the first one put me off, not to mention its hard to say, but it does look like it has cracks in the glass on the pendulum.
43 minutes ago, clockboy said:
I got it wrong I am was really surprised that the movement with a mercury pendulum has such a basic movement.
Thats why I am a amateur I suppose. B)
They are extremely good movements made with very hard brass and steel.
12 minutes ago, clockboy said:
Agree I have serviced / repaired many of these movements and they are really well made.  I just was expecting something better/unique.
I'll see what I can do the next. I'm always looking for something different but not to difficult to keep the clock section interesting.
    • An update, for everyone who contributed advice, and for those who come after with a similar problem. Based on the answers received, I decided to work on the face of the hammer first. I used a square degussit stone to guarantee a vertical surface to work against, and ground the face back until it was square across 90% of the depth. I was conscious of the risk of removing too much material.* After I'd got the shape how I wanted it, I polished the surface with lapping film. To cut a long story short, it did the trick and the hammer hasn't slipped off the cam since. Of course, that wasn't the end of my problems. Have a look at this video and tell me what you think is wrong. https://youtu.be/sgAUMIPaw98 The first four attempts show (0 to 34 sec.) the chrono seconds hand jumping forwards, the next two attempts (35 to 47 sec.) seem "normal", then on the seventh attempt (48 to 54 sec.) the seconds hand jumps to 5 sec. and the minute counter jumps to 1. The rest of the video just shows repeats of these three variants. I solved it by rotating the minute counter finger on the chronograph (seconds) runner relative to the cam.  I'd be interested to hear your opinions on that. It seemed to be the right thing to do, but maybe I've introduced another problem I'm not aware of. * What is the correct relationship between the two hammers and cams, by the way? Should both hammers strike the cams exactly at the same time, or is it correct for the minute counter hammer to be a bit behind the seconds hammer? In this picture, I removed the adjusting screw at 1, and the hammers are contacting the cams simultaneously at 3 and 4. I had to turn the screw down tight to achieve this condition after stoning the seconds hammer and replacing the bridge.
    • It was easy enough to pop off. Once I had the cannon pinion hanging on the blades of the stump, I got my #2 tweezers on the gear attached to the staff and levered it down. That way none of the force was on the brass wheel itself.   I reinstalled it and the bridge, and it looks like a small but reasonable amount of end shake. It also spins easily with a blower. It stops quickly, but I think that's due to the large shoulder and about what I'd expect from this wheel.
    • Oh, right. For some reason I was picturing a monocoque case in my head. Good looking watch!
    • Well said Ross. My reason for the thread, i like many of us dont want to lose the forum, such a well knitted group of individuals i feel. But things can happen out of anyone's control. Would be nice to have something in place just in case, if anyone has any ideas please speak up.
    • Ok thanks Ross, I will give that a try!😁
