Watch Hand Removal - Tool & Technique Choice
This part is dusturbing… The UK is no longer part of the Lugano Convention, whose rules Judge Green has applied, and as yet nothing permanent has replaced it.
I was not aware of that as I'm not familiar with the 861 calibre but I was speaking in general terms. Thanks for pointing it out! I thought it was somehow resting/rubbing on a very small section on top of the barrel. So, not really an exception to the rule then. Good to know!
Yes I have that in my watch list a JUF if cheap enough I will have a go , if nothing else it will be good for spares, I have a few JUF’s
Less give a damn- more **BLEEP** it! …nice that it is keeping time I’ve done a couple of these (one with your assistance) and there’s a third that needs work on the tension between what drives the hands and the barrel. Did you have any issue with that? …and I saw Ranfft make a small comment in a thread re: pin pallets- a couple drops of Tillwich blu, let it run down the pins. It is good for 20 degrees of amplitude… I’m using this oil as a cheat code on my unmotivated Venus chrono…
