What tool do I need to fit Rolex 1570 GMT hands?
chriz74
Hello, I have to send my Rolex GMT with 1570 (1575) caliber to Rolex Geneve for servicing. Since it's not clear what their policy is regarding yellow patina dials and hands (people tell they remove the old dials from watches and fit new services one then they keep the old parts). I need to save those parts from their hands so I need to fit a service dial that I own and some aftermarket hands.
I see that cousins has a box with all the hands but I need to know what tool I need to fit the hands back. I saw those horotec as in the picture, I don't know what diameter I need.
Does anyone know? the gmt has 4 hands the larger diameter one is the 24 hours hand. Also how do I hold the hands while refitting? I have antimagnetic tweezers already.
kyrBvfk.jpg?3
If you send the Rolex to a Rolex centre for a service they will change any aftermarket parts back to original Rolex parts. That was their policy a few years ago for sure. My wife had a Rolex but it had been fitted with a mineral crystal and it should have had fitted a acrylic crystal. They informed me if they serviced it they would have to re-fit a original acrylic as it was company policy.
I already did that and they don't reply. I asked specifically about the dial / hands. Their reply:
"...Furthermore please be kindly informed that we will only be able to answer your questions after your watch has been examined physically.
Once received, we will be able to provide you with our watchmakers feedback and we will inform you when it will be ready to be sent back to you.
This estimate will contain detailed information about the necessary and optional services as well as their prices."
I don't want to waste time and money sending the watch to discover later that they refuse to service it without replacing parts.
2 minutes ago, Ray said:
Personally I'd never send any of my watches to a service centre. If I couldn't do it myself then I'd much rather use a quality independent watch maker. Half the price and you're likely to get it back a lot quicker.
Well, unfortunately all the watchmakers in my town are prone to lie and disaster making, there is no one that has specific Rolex training nor that can have Rolex parts and no one that is able to polish the case as it should be done. The case needs some restoring (some little parts to do with laser welding) and nobody does that here. Independents in Italy ask 500/1000 euros just for the case! So it's obvious it doesn't make any sense to give the watch to an indipendent here when I can get the job done for half the price at Rolex and get a 2 years warranty. The last time I gave this watch to an indipendent here he kept it for 4 months and an half and was not able to fix it.
To come back to your question: I bought this official geneva set a year ago and it works fine for me working on my rolex watches.
http://www.uhrenwerkzeuge24.de/werkzeug/zeiger-glas/3-zeigersetzer-official-geneva-basic.php
Concerning the process: There is a very good video from Mark on youtube where you can see how to fit the hands. Just google for "servicing rolex 3075".
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
