Another loncase on ebay
atimegoneby
It’s not a longcase clock its what’s called a corner granddaughter with a 8 day Westminster chime English movement dated 1936. Typical brown furniture of that time in fact most bedroom furniture looked that way. What a horrid looking thing it looks too. The price is a bit steep; I certainly don’t think it will sell.
If you copy and paste the link in your address bar that is how you add a link.
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
