Watch of Today
mk3
1 hour ago, Jon said:
Wow... great watch! I'm really appreciating Seiko's at the moment. Where did you get that strap? That is absolutely amazing. Thanks for sharing that with us
Hi Jon , I'm assuming you are asking me about the Sting Ray strap on my Grand Seiko ......Most I have seen come from Indonesia or that part of the world at a very decent price . Sting Ray is some tuff stuff and looks , to my eye anyway , very handsome on most watches .
I had a very conservative black leather watchband on the GS , but I never wore the watch , so I decided to spice things up a little .
This is an interesting watch. It belongs to my Dad and it was gift from King Hussein of Jordan in 1969. My Granddad and uncle - via ham radio in Ilford - were King Hussein's only communications link with the outside world in the 1969 civil war with Palestine. After the war he sent them 2 personalised Longines watches. My Dad inherited this one from my Grandad. He's asked me to service it for him which I'm planning to do this weekend. I also want to look into getting re-plated as the gold has worn away quite a bit. If anyone knows anyone in London who they can recommend please let me know.
replateit.com
I have not used this service myself but, have heard only good things about them.
That is a great story. I love when a watch has a notable provenance. Good look with the overhaul--easy does it and take your time!
I've used Replateit many times and Peter has does a fantastic job with all of the cases I've sent him....both Gold plating and Nickel/Rhodium.
J
Edited by noirrac1j
On 9/12/2018 at 8:26 PM, ricardopalamino said:
Back to the future today...A West German made electric back set Timex....
My pics don't do it justice .
1023497123_ScreenShot2018-09-12at8_18_44PM.thumb.png.c591975b6500750c61ffdd58e3a609c7.png
767909645_ScreenShot2018-09-12at8_19_24PM.thumb.png.b3432d3ef6451cc6592da80d81beab91.png
175900406_ScreenShot2018-09-12at8_20_14PM.thumb.png.558813f1230ab4c4cad033351c34e6d7.png
I got a new brown leather watchband for this baby....
730242930_ScreenShot2018-09-15at9_11_29PM.thumb.png.97f9a48d14294d9047b14977b98b0fcd.png
For some reason , don't know why  but Timex watches have been on my radar lately . Kinda like visiting an old friend I hadn't seen in a long time.....
653266270_ScreenShot2018-09-15at9_13_57PM.thumb.png.79de53a443776a2fa6359f92ca38a85a.png
I need to start looking at old catalogues but I’m sure my first ever watch was a boys three hander on a black strap in I would guess about 1976. I seem to remember having it in the deep snow and I think that followed the hot summer of ‘76. Would I recognise it if I saw it? Maybe.
3 minutes ago, ricardopalamino said:
Hi JerseyMo ,   Very nice Timex . At first I thought it was a Marlin because of the hands . I really do like those baseball bat looking hands that Timex used for their Marlins and Viscount along with the lume dot above the index's
Yes, Timex did have a nice mix of different hand styles.  The one issue that can be a pain is with the second hand only having a center hole and no tube to help hold it in place.  Often after a repair the seconds hand tends to not fit so well due to the hole having been elongated during removal.  For this I have two fixes, first is to place the hand on flat metal surface and use a flat punch to peen down the area.  If this still does not quite get the end result I dab a dot of clear nail polish to the underside and quickly fit it the movement.
You're a brave man working on Timex's...
A 1968 Timex 'Sprite' 24 Hour Black Dial -   It is the first year model with the distinctive white hands which paid homage to Mil-spec of the same era.  I cleaned and lubricated the movement, install a NOS crystal , crown stem, and matched it with signed stainless steel bracelet.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
