Watch of Today
mk3
Driving the desk today, so got an OG desk diver on the go.
Duward Aquastar Oceanic. A 200m rated EPSA Super Compressor with an Adolph Schild 1903 movement. Keen to find a 21** version of this movement to play with if anybody has one laying about.
Reminds me of a Tissot, down to the flat-side caseback!
Anilv
Agreed.....no offense of course.
Im just not a fan of the rolex fluted bezels...not even on the DJII
Even on my stainless I much prefer the engine turned, although if I could have had smooth I think it would have looked better with he tapestry dial.
Edited by Horologent
No offense taken at all .
I really wanted this Submariner for a while , and paid dearly to get it ...
938863556_ScreenShot2018-09-05at10_21_44PM.thumb.png.814a86f41574ba24f3740f46665c89e8.png
Then after I got it , I didn't wear it at all . And to add insult to injury , I lost about 2K as soon as I walked out the door with it .
I recently traded it for an Omega Moon to Mars watch  a couple of Baume Mercier watches , a Cherry Seiko diver , and a very Blingy 14k gold an diamond ring . And I feel good about the trade ,....go figure .
1636978117_ScreenShot2018-09-05at10_31_41PM.thumb.png.2f2bc2f26a87f489411ce57e6d9f345a.png
907171913_ScreenShot2018-09-05at10_32_08PM.thumb.png.746b052690b3f0332ea4de90e0fe9e42.png
854842126_ScreenShot2018-09-05at10_32_28PM.thumb.png.30d39f652efa39ce0f22ee598f8a439c.png
I do like the Omega....
1320095545_ScreenShot2018-09-05at7_47_35AM.thumb.png.62ead0dce805d175549678bc4dbcf413.png
Y'all do have some mighty fine looking watches there! I admire Rolex for its build quality, but Omega is my preferred piece.
Sent from my SM-J727T using Tapatalk
Hi Joe ,  You Always have nice positive things to say . I can admit my affection  for Omegas too .
Especially if I can throw a Hamilton into the mix every once in a while ...
7 minutes ago, ro63rto said:
Been wearing this today
Bought for the price of a large Pizza Hut pizza. It was in a right state.
Looked like this when I got it...
No crystal and God knows what it was covered in.
 That watch looks like it's covered in Moon Dust ....
Nice job cleaning it up .  Is it supposed to have a center second hand ?
21 hours ago, ricardopalamino said:
No offense taken at all........I do like the Omega....
I would take an Omega over a Rolex any day of the week and twice on Sunday. The orange bezel PO is awesome.....Ive had a couple speedys and seamasters over the years....loved em, but that co-axial is redonkulous. I have an Omega coming soon that i think everyone will get a kick out of.....
Let’s go back to the days when Heuer became Tag Heuer. The is the black ip professional all lume dial. This was available as both Heuer and Tag Heuer depending on where and when you bought it. It was also featured in a James Bond film before the days of Rolex and omega.
Amazingly, the lume is still bright and clear, just doesn’t last as long as it once did. This beauty is too small for me now and I lost the extra links long ago, so it sits on my bench to be my time setter after changing batteries.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
