Watch of Today
mk3
On 2018-04-15 at 4:29 AM, anilv said:
Wearing a Fortis 'True-line' this Sunday.
It's an automatic with an ETA 2452 inside. Bought it cheap a few years back as it was not running,  a service and it's running fine. It had a generic crown which I swapped out for a used original I had around.
It has shrouded lugs which is a nice design feature and with the date at 1 o'clock it's quite a unique watch.
Foetus is a brand rich in historynd their recent models are quite ice but is sad that they had to declare bankruptcy last year..  Hope they make it through.
Anilv
Reminds me a lot of this recent acquisition, something about the case shape and dial really works for me.
Wow.. this Seiko is practically NOS. Can you share a picture of the caseback?
TIA
54 minutes ago, noirrac1j said:
Oh nice Sicura! Does this have the venerable gold standard of pin pallets--BFG 158 31/7?
J
Hi Joe ,  I don't know much about these watches so I opened the caseback to take a peek and I did see the number 158 under the balance wheel ,...so I guess it is as you described .
5ae0af97d09a3_ScreenShot2018-04-25at10_38_44AM.thumb.png.0fd819f9c8113d419f4fbfa5e7f7c313.png
5ae0afe09f663_ScreenShot2018-04-25at10_39_52AM.thumb.png.194405ea122306780982d3fb0b6a6c86.png
Edited by ricardopalamino
5 hours ago, noirrac1j said:
Yes it does! Its a good, strong movement that is relatively straightforward to overhaul. Your example looks nice & clean. It will probably many years of service, but If you ever need spare parts, I have plenty.
J
Thanks Joe , Good to know you have my back on these parts .
The Best ,
Louis
Hi Tipsy,
Nice Skyliner! Your post made me dig out mine and give it some wrist time. its not as nice as yours though but in actual use the wear in the dial is not really an issue.
I haven't opened it up as its working fine. Serial number dates it form July '67 which makes it 51 years old!
On 4/25/2018 at 1:51 AM, Tipsy said:
Another Seiko from about the same time as the one above - Skyliner 6220 - 7970.
First watch I took apart, keeper that do not get that much wrist-time.
1 hour ago, anilv said:
Hi Tipsy,
Nice, the serial number on mine is 7700053 and when I run it to check - it also was made in Jul 67. There are some true vintage gems right before the quartz crisis.
    • Thanks for the help guys! VWatchie I already found your thread but I'll check it again. Nice to know about acetone, I still have to get the shellac off since I made a little mess. I adjusted the jewel, put new shellac (the so called soldering technique, pallet tool too hot this time so the shellac "wire" melted in air before getting in contact with jewels or fork) rinsed the pallet fork and put it back dry. Amplitude is now in the 240-250 range that I expected in the first place. I guess there's enough oil in the escape wheel teeth already but I'll check that later. The mainspring was pretty beaten so a new one would probably boost the amplitude even further. Nice to learn new things. Now I have another thing to look for while disassembling. I wonder if the watch left the factory that way.
    • Would be interesting to see it 🙂
    • These are all American movements (with the exception of the "Rubis"), and are all almost certainly "negative set" which means the stem is part of the case. So it's normal that they are all missing- they are with their cases. You will need male square bench keys to wind/disarm them. Vintagewatchstraps has a great writeup on the different systems. But basically, any American "x" size movement will fit any case for that size, possibly with some adjusting of the stem position. With Swiss movements, there is some interchangeability between calibers, usually within the same maker's range, but not really overall- there are thousands of different stems out there.
    • Hi, I'm very new to watchmaking and this is my first time posting here.  I've bought a lot of 10 vintage pocket watches size 0s from e-bay and just got them today.  Most of the balance wheels sprung quite freely and thus seemed like a worthy endeavor as a first batch for exploration.  I've just realized that none of them have any winding stems. Is there any way I could source appropriate winding stems for the movements? There seems to be assortments of various stems selling in bulk on aliexpress, but would any of them fit?  I've read on other threads that some people lathe their own stems (which is waaaay out of my current skill set, which is pretty much nil). Others say that you 'just have to try a few and see if they fit'. I would much appreciate any advice for this matter. Thanks!
    • Nice work.  In the last year, I have been servicing Accutron 218s.  I have the official Accutron hoder that provides electrical contact to the movement.  It is a pretty clever design.  There is a cut in the ring of the holder (shaped like a "C").  When in relaxed state, the holder is slightly smaller than the watch movement.  You spread the cut slightly and drop the movement in and release.  Very clean.  I have made 3D versions of this setup.  Have not explored using it generally for other movements.
