Watch of Today
mk3
Aloha Watch Fans , ...I've been pretty busy for the last couple of months and haven't posted any of my watches lately .
I'd like to remedy that by sharing a couple of Heuer and Tag Heuer chronographs from my collection .
!st off is this Heuer by Tag Heuer Monaco Chronograph . The model # is CS2111 and is what is called a re-issue or re-edition of the classic Monaco brought to fame by Steve McQueen's Blue Face version in the movie " Le Mans'....
Some tidbits about the watch...
http://www.timeandwatches.com/p/history-of-tag-heuer-monaco.html
https://www.calibre11.com/tag-heuer-monaco-re-edition/
The watch....
The next watch I would like to share is this Hefty Tag Heuer Carrera Caliber 16 . This watch is powered by a Valjoux 7750 . When I first got the watch it was in need of a service highlighted by the fact that when I hand wound it  , the oscillating weight would also spin causing a drag on the winding stem and causing the watch to wobble . I serviced it and am happy to report that it is purring like a kitten .
  This watch features a portrait of race car driver Juan Manual Fangio On the case Back .
I hope you enjoyed looking at these watches as much as I do .....Thanks , Louis
Another NOS Benrus..same as the stainless steel version I posted earlier. I purchased a lot of 19 NOS Benrus watches and I'm slowly getting them back in running order. They've been sitting around in their original factory shipping box for over 40 years. Most had broken crystals and some had calendar issues but they all seem to just need a good service to get running correctly... They'll keep me busy for a good while!:blink:
9 hours ago, ro63rto said:
Today is one from the USSR
Still have to re-lume it though.
Sent from my Honor 5c
Ok, I need your watch! I have this unique Day date dial movement combination. I need to find a case for it and yours has the exact dial shape that I've been looking for! It's kind of unique since it has a full day display and date on the same line..
If this watch looks familiar it's made up of a bunch of homage pieces and parts.. a Tudor black Bay case, a jaeger-lecoultre master compressor dial and hands, and a Rolex Submariner ceramic bezel.. none of it fit together out of the box I had to do a lot of Machining and modifying to get everything to fit together. Even the movement, it is a ETA 2834 with the day wheel removed and the expansion ring for the 13.5 line size..
I have been wearing this really nice Seiko SRPA21 PADI Turtle Limited Edition I just got....Love it....
598e6db23f401_ScreenShot2017-08-11at4_42_46PM.png.cad5e5c525b0deeb6d0d7ce1e2f923f7.png
598e6dc8bc779_ScreenShot2017-08-11at4_43_56PM.thumb.png.ee79ac06d8f4f330a6a2cd838a56fa97.png
I have attached a link to a review of this beauty...
I have also recently picked up this 1949 Hamilton "Franklin" . Excellent refinish done to this watch , It looks new . Also , it comes serviced by a 3rd generation watchmaker and has a 1 year warranty .
598e70b87164a_ScreenShot2017-08-11at5_05_10PM.png.a71175315ffe921b600f3769b843a292.png
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes. A search on ebay UK for "spring steel strip cs" finds plenty available in small quantites and thicknesses from 0.1mm up.  But the question is ( @nickelsilver) which "CS" number is best for watch parts ?  Also, from one of the ads : "CARBON SPRING STEEL. SIZE IS METRIC 15.00mm X 0.10mm X 304 MM  CS100 FINISH BRIGHT . HARDENED AND TEMPERD TO 480-530VPN" I've no idea about 480-530VPN. Does that mean it needs annealing before working?
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
