Watch of Today
mk3
Today its a Vostok Amphibia from the 80's I think I'm sure someone will put me right. Its one of a group of 4 I won on the bay all none running but with a set of 4 movements used as spare donors purchased from the Ukraine for £5 yes that's 5 whole English pounds including postage they've all been serviced and are running a dream 3 of them including this one I had to re-lume. Now I have a dilemma do I leave them be or do I mod them ie pepsi type bezel new dial nato type strap or should they be left original your thoughts are as always welcome.IMG_0506[1].JPG
To me the answer is easy. Mod away! Just carefully mark and store the parts that you replace, so that you can restore the watch to original condition if you want to. Even if you sell the watch, you can offer the parts to the buyer, or if they are not interested, then you have parts to restore other watches!
think I'll try one to start with I know some people like to mod but there's something about a watch in its original state with chips dents an all it shows its age I think I'll mod one to sell see if I make any money back or I may really like it and end up keeping it :D
P_20160802_194253_1_p.jpgWearing hand-winding Rigi, I believe it has a ST96 movement. Has red accents on the hands, markers and rehaut (minute track).
Being a handwind it's quite thin and sits nicely under the sleeve.
This watch came from Turkey and others I've seen on the net cone from there as well. Local brand?
BTW that's not a modified bezel insert. The markings are painted directly on the bezel and it has worn round the edges, giving the impression that someone has modified a bezel from another watch to fit.
Anil
Wearing a hand-wind Elgin. Got it with a badly damaged dial with the lacquer lifting off...gave it a scrub and underneath was this nicely suffered finished. Powered by a nice Elgin 524 movement.
Have a good weekend everyone!
Anil
Looks as though the square ones are a little rare...
The one above now has new hands fitted, those originals had really faded and discoloured--not so easy to see in that picture so have been replaced--exactly the same type--but nice bright and clean with fresh lume. The faded day-glo almost yellow seconds-hand is now replaced by nice new bright orange one.
Only the case and crystal left to sort out......Then I'll have to stop wearing it every day for fear of damage--No free lunch!
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
    • Don't forget Mark is a hard working watch maker so he is also tied up with work. I'm sure he is keeping his eye on this forum making sure it is running along nicely.
