Watch of Today
mk3
Hi all,
Wearing this Vulcain 'Meteor II' today. Don't you just love these funky names? I've always had a soft spot for Vulcain..a lot of it is due to the name itself and the logo (as on the caseback below)..
Inside is nothing spectacular.. just an ETA2452...tried and tested (sorry no pics)!
Anil
It's a Mondia for me today.
My first "proper" watch was a Mondia Sea Scout. It was my 16th birthday present from my parents and I still have it, but it was the start of my interest in Mondia watches and I now have 5 of various vintages. This one was an eBay non-runner that required no more than a service and clean up.
Nice job on that Sportmatic BL.
Geo I reckon you earned that test drive several times over.
I was out on site today so went for something a little more robust than I would for the office.
Citizen Promaster, a nice big solid reliable chunk.
I love the dial on that Omega.
Today I grabbed this Seiko Alarm Chronograph watch to be my watch of the day. You don't see many of these around anymore or fully working ones, especially considering that they used to be so popular at one time.
post-1462-0-82828700-1445619709_thumb.jp
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
    • Don't forget Mark is a hard working watch maker so he is also tied up with work. I'm sure he is keeping his eye on this forum making sure it is running along nicely.
