Watch of Today
mk3
11 hours ago, GomBoo said:
TETO
They Eat Their Own? ? Oh.. to each their own...
... well if you think that thing is off the wall, I'm sure I have some much, much odder stuff.
Maybe I should start a separate thread for the most off the wall watches.
I second the motion that you should start an "off the wall watches" thread.
 I really like the 1940's art deco style but it's hard to find a large case. This one is unusual in that it's 28mm.
It's one of my top 3 & I probably wear it as much as my black strap watch because oxblood goes with almost everything.
Edited by SuspectDevice
  • Like 6
Well it certainly isn't shy about letting you know it is ticking.
Its actually not too bad (for a 1967 Timex mechanical).
Not exactly COSC, but not bad, given that it is a slightly agricultural bit of 1960s technology, which almost certainly has only been serviced once in its lifetime since it left the Dundee factory all those years ago. Its seems to have survived my servicing reasonably well too, since it is still going strong more than two years later.
Edited by AndyHull
Thought I'd show the watch I've been wearing for the last few weeks, picked it up and gave it a bit of a clean and a strap I had and so far it's keeping great time can't find any info online about the make though ☹️ (if anyone knows anything I'd be happy to know)
Tried taking the scratches out of the crystal with polywatch but no joy so that might have to be replaced.
This is my next amateur horology victim.
It has been apart twice and I'm still having problems. Maybe the 3rd time will be a charm.
I found a chipped jewel the 1st time & fixed that. The 2nd time was a new mainspring (ETA 900 you have to lift out the train bridge instead of just popping the barrel out)
Anyway...I still like the art deco watches and they apparently call this one a "bottle cap" (Bulova made a bottle cap also)
Did you hit it with sandpaper first?
For this one, I would work it over with 800 grit (or maybe 600) and then follow up with 2000.  Then polywatch.
The thought of taking sandpaper to a crystal is terrifying
I know it would work but it's still terrifying
isn't just the sandpaper, you have to use a rotary tool also. Unless you want to spend 4 or 5 hours at it and end with sore arms.
With a crystal like that I would start with a small piece (1"x1") of 180 grit wet & dry working under a running tap, then work up through 400, 800, 1500, and 2500, all under running water. Then polish with Solvol AutoSol. Maybe 10 minutes max start to finish and will look like new.
If that is about a plastic crystal most of the time sandpaper is not needed, abrasive compound works good.
Even for mineral glass in my experience of doing many I have found that stepping through so many grades of paper is a waste of time and money, two grades plus diamond paste are enough.
Full topic
  • 4 weeks later...
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes. A search on ebay UK for "spring steel strip cs" finds plenty available in small quantites and thicknesses from 0.1mm up.  But the question is ( @nickelsilver) which "CS" number is best for watch parts ?  Also, from one of the ads : "CARBON SPRING STEEL. SIZE IS METRIC 15.00mm X 0.10mm X 304 MM  CS100 FINISH BRIGHT . HARDENED AND TEMPERD TO 480-530VPN" I've no idea about 480-530VPN. Does that mean it needs annealing before working?
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
