Watch of Today
mk3
21 hours ago, AndyHull said:
Keeping warm by the fireside tonight while a Baltic wind howls past the chimney, so what better than a little bit of Russian company. No, not the high octane fighting potato juice, just a bit of submarine themed Vostok 'Komandirskie'.
Beautiful dial! What could possibly be better than a Diesel Boat dial, eh?! ?
I will be searching eBay hoping to find one like yours.
Will covert my Generalskie into Komandirskie ?
Edited by Poljot
An HMT "Sandeep" joins me with a little light reading material by the fire today.
The dial on this is particularly difficult to photograph. It is a rather pleasing bluish grey, but that doesn't really come across on the camera. Digital cameras for some reason seem to struggle with rendering blues accurately. This one is from 1995 which makes it one of the newest watches in the collection, and it actually still looks very fresh.
Edited by AndyHull
This was going to be another "Timex Tuesday" watch, and then I thought I might make it in time for a "Timex Thursday" instead but it took a little more work than I expected, so I guess its a Timex Friday today - 1971 Timex Viscount (model 46660 3271). I lost count of the number of times I had this apart, but now its fully functional and clean as a whistle.
Edited by AndyHull
On 12/14/2020 at 10:55 PM, AndyHull said:
I'll take a look tomorrow and see if I can find a suitable dial for you. What size is it? Where are the dial feet positioned? Did you get the caliber running?
Not yet. I took it apart and the only thing kept me going is that it seems i am a very bad watchmaker so a little bit of practicing was just one step forward in the right direction. I cleaned the parts manually because they were very dirty and some of them are rusty too plus my ultrasonic does not work anymore and the national watch cleaner machine project has not even started yet (apart from buying a cable and a corc sheet). I got some green stuff here and there which reminds me the stuff u get when a battery is leaking. All in all i think a new dial would be a waste for this movement, but I am going to try to put it together anyway. Going to post about the result.
Today's casual watch is a Elgin Automatic which I assume is from the 70's. I know very little about it. I won it in a Goodwill auction for around $38 and it showed up not only running but keeping impeccable time as well. It has an AS 1916 movement.
Edited by Rdot84
I decided to give the elegant little "Crown Watch" "Ancre 15 Rubis" an airing today.
This has a strange arrangement of "almost fixed lugs", in the sense that they have pins that roll, but are so tightly fitted that there is no way to remove them, so it requires a strap suited to fixed lugs.
I can't remember what the caliber is, but for those who want to know, here is a picture of its beating mechanical heart.
I would suggest it is probably from the 1940s or 1950s judging by the styling, but that is simply a guess, so possibly from the Bombay "Crown Watch" company, or.. possibly not.
Edited by AndyHull
    • You don't have to use his special tester. Any good multimeter would work.
    • Yes, it looks like GT Revue 30. Doctor, You can not replace escape wheel by the dimensions You listed. One needs to know much more things like number of leaves of the pinion and it's diameter, the position in high of the table and the pinion, the hight between the pivots, the exact pivots diameter... And then, even if suitable wheel is found, one will need to know how to adjust the pallets position correctly. Restoring antique movements is something different than replacing parts. In older movements parts are not interchangeable, this means spare parts do not exist. Here the case is different, but still escapement adjustment will be needed if a wheel from a donor is found. So may be it will be easier to restore the donor for You...Restoring antique movements usually means making of the parts needed and this requires knowlage and working on lathes skill. In this case repivoting of the wheel is the natural solution, but there is a long way that one must walk untill getting ready for such work.
    • I was looking at Essence of Renata, a chemical used a lot for cleaning hairsprings: "Specially prepared solution for degreasing watch and instrument components. Indispensable for degreasing hairsprings." Looking at the MSDS you can see this is just pure n-Heptane, so could be an option for those who don't want to use the chlorocarbons or hexane?     HF6013 - Horological Essence COSHH Safety Data Sheet Horological Essence_0.pdf
    • Welcome from a fellow Seiko enthusiast, there are lots of us on this forum.
