Thanks again, Dell. I'd already enjoyed your set of 8 YT videos! Photo attached.
By MartinOfPrague · Posted
All right, so here is the most likely explanation: one of the dial feet is broken off, therefore the the dial is not well centered and the short tube which is a part of the hour hand probably rubs against the edge of the dial hole. Thanks again for all the suggestions, though! -
thinking about your movement I don't recall you giving us the movement number? I snipped out an image I can sort of read a C0 but not quite sure what the rest the number is so could you give us the exact number.
