Watch of Today
mk3
Today it's the Benrus Citation electronic watch. I recently pulled this apart to clean it. It had a very tall battery in it and the hatch wasn't sealing so moisture was getting in and everything was beginning to stall. Next strap I buy, will be a replacement for this ugly thing.
A while  back I posted  a urika hamazawa..It was  really  worn past practical  repair..If you are familiar  with  the hamazawa  movement  ,you know  it's  quite tall. So  I conducted  an experiment...Urika  case ... dg2813  movement...generic  29mm sterile dial generic hands  ...."custom"  plastic   movement  holder ring and bulova water proof  crown. It all lines up..works  like a charm..something  to think about if you have an old non working  hamazawa  you want to play  with.
Today I slipped on my Pam homage I made myself from eBay parts. I fell in love with the Panerai PAM00672. The classic shape of that case and the eye catching engraving caught my eye. I happened to see a "replica" of that case on the Bay and picked one up. I also grabbed a Sea-Gull 6498 movement and a sleek black California dial with matching hands. The strap came next and I chose one that looked the part. The correctly engraved clasp was ordered last to make it complete. I get compliments all the time on it.
  • Like 5
13 minutes ago, Nucejoe said:
Camy powered by ST90, made in India I believe.
Check prices, real inexpensive.
.. and a fine looking bunch they are too.
I would not be the least surprised to find an old friend (the HMT 0231) lurking inside at least one of them in place of the stated "ST 90" .. (which probably actually refers to the Standard FHF 96).
There is only one way to know for sure, and that is to take a peek inside.
Edited by AndyHull
I see, picked them yesterday,  dosn,t ST96 variant have a calender, got them for about 30GBP. Cheap even as a practice piece.
Merry Christmas Andy.
Enjoy them whatever they turn out to be. :biggrin:  So far as I know, and I 'aint no expert, the standard  "Standard 96" doesn't come with date complication, however there may well be variants that do.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&Standard_96
If you search Ranfft for ST 96 or "standard", you will see there are many variants, so one with date is a distinct possibility.
Have a great Christmas, and New Year. :thumbsu:
My blue dialed Citizen Crystron Quartz enjoying a bit of early morning Indian sunshine, makes another appearance today.
It appears to be from July 1980 (not 1985 as I previously stated), which makes it around 40 years old.
It is a Citizen, though, so it is barely run in. :P
You were right Andy,  ST96 under the hood.
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
