Watch of Today
mk3
On 12/3/2019 at 5:11 PM, yankeedog said:
Most esteemed  friends...I present  to you my Mumbai  Homage. Old amphibia case with 2209 movement. A glorious  fake dial glued in place. However, unlike  most fakes you will find the 200 meter rating  is legitimate. I am sorry..I just had to.
THAT is stunning.
A genuine Voslex Amphibimariner, ultra rare status on the eBay 'rare' scale. :woohoo-jumping-smiley-emoticon:
7 hours ago, watchguy74 said:
Not that I could see was hoping you might know.
Sent from my SM-G975F using Tapatalk
You would probably need to remove the mechanism, to check. The date code, if there is one,  will be below the level of the crystal, and not visible without removing the movement from the case.
EDIT: I didn't know Timex did "jump hour" digital watches, but a quick google trawl shows a couple of examples including one with a Swiss jeweled movement.
Strictly speaking it isn't a "jump hour", but a direct read digital. I couldn't find any similar examples, so it is also fairly rare. Maybe not a true jump hour, but none the less, it is pretty neat. I want one. :D
Edited by AndyHull
20 hours ago, watchguy74 said:
Picked this up recently do not know much about it but really liking it maybe@JerseyMo may know something about it as he is the Timex king emoji16.png.e4825025dd43271e32be2ec26c7deb9d.jpgd20dab400dc467c5c59af00e85bacb4c.jpg
Does the white "TIMEX" disk rotate around a static dial disk with the numbers on it, or does the numeric plate rotate under a fixed white "TIMEX" disk?
My guess is that the dial is fixed, and the "TIMEX" plate is effectively a circular plastic hour hand with a window that shows the numbers on the dial beneath, in which case it is a very similar arrangement to my tennis playing Snoopy with its transparent second hand with a tennis ball on it.
Edited by AndyHull
Yes the Timex disc rotates around like a minute hand.
A nifty solution, since this allowed them to use a standard mechanism.
Did you find the dial style number?
It will be printed on the metal dial disk down at the 3 O'clock position, and as I said before, you  may not be able to see it without removing the mechanism from the case.
My guess is that it starts with 3XXX the last two digits will be the year of manufacture.
There isn't any numbers anyplace I can see here is photo with dial removed.ea433dbd3a13b3b34d56291326a27aba.jpg&key=9d016f3e262e3e0e41b33e4ebc583d07bd2a86c45022f748b4736da37ec155fe1526e954cfa3f93e4af71d126cb6378e.jpg&key=be32c074b56ef63cc965645c4529d89e5382d5fb8d9ef75ee70ac2d842339ada
I wonder if this is a prototype? An idea Timex toyed around with and developed a prototype and possibly a few sales samples and then abandoned without going into full production. We can estimate the age by the movement, if it dates to the late 60's through the late 70's, then Jump hour/ direct read watches were en-vogue. Many companies develop products without ever going into production, this may very well be such an example.
The number might be visible if the hands were removed, but that seems like a slightly dangerous move.
Typically it would be on the dial plate, so in this case,  the circular hour hand would be covering it completely.
No worries, the exact designation is of purely academic interest. It looks too well finished for a prototype, but you never know of course.
No doubt some former Timex employee (in Dundee perhaps) might know the history of this particular piece.
Having worked for many years in manufacturing, my experience allows me to make a few assumptions. If Timex was ramping up to begin production on this and the market for this type of watch suddenly crashed, (which it did) they would very logically pull the plug on it. There could easily have been a small handful of these of a more refined quality than a crude prototype. It is also logical to conclude a former employee may have ended up with this piece because of their access. In any case, it is an amazing watch.
Today's watch is my vintage Vostok Komandirskie. You may recognize it as the exact model Mark featured in his recent YouTube video with the pallet issue. I liked the one he chose so much, I had to get one for myself. I absolutely LOVE the patina on the dial. As Mark mentioned his was a bit of a Frankenwatch, mine is as well. Amphibia case, Komandirskie movement and dial and a no name bracelet that was once two tone gold and stainless but the gold was scrubbed away. I'm still waiting on my scuba dude like the one mark also featured, but that one is taking the slow road from Russia:rolleyes:
I would  call it an amphibia with a komamdirskie dial. It is after all the case that qualifies it as an amphibia. And since  it is a 24xx movement  current  production  dials from mother  Russia will  fit.very cool.
AS1187 powered  Mondia. This one runs pretty  nicely. About 220 degrees  amplitude  10 seconds  fast at .7 ms beat error..curiously it is all stainless swiss cased..and has an acceptable  beat error. I have noticed  that  very  often  cheaply cased AS1187's  have pretty  large  beat errors. Factory  seconds maybe.Or hasty  off shore  assembly.
Amphibirskie or Komanphibia...hmm:D
    • Ok thanks Ross, I will give that a try!😁
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
