Watch of Today
mk3
On 12/3/2019 at 5:11 PM, yankeedog said:
Most esteemed  friends...I present  to you my Mumbai  Homage. Old amphibia case with 2209 movement. A glorious  fake dial glued in place. However, unlike  most fakes you will find the 200 meter rating  is legitimate. I am sorry..I just had to.
THAT is stunning.
A genuine Voslex Amphibimariner, ultra rare status on the eBay 'rare' scale. :woohoo-jumping-smiley-emoticon:
7 hours ago, watchguy74 said:
Not that I could see was hoping you might know.
Sent from my SM-G975F using Tapatalk
You would probably need to remove the mechanism, to check. The date code, if there is one,  will be below the level of the crystal, and not visible without removing the movement from the case.
EDIT: I didn't know Timex did "jump hour" digital watches, but a quick google trawl shows a couple of examples including one with a Swiss jeweled movement.
Strictly speaking it isn't a "jump hour", but a direct read digital. I couldn't find any similar examples, so it is also fairly rare. Maybe not a true jump hour, but none the less, it is pretty neat. I want one. :D
Edited by AndyHull
20 hours ago, watchguy74 said:
Picked this up recently do not know much about it but really liking it maybe@JerseyMo may know something about it as he is the Timex king emoji16.png.e4825025dd43271e32be2ec26c7deb9d.jpgd20dab400dc467c5c59af00e85bacb4c.jpg
Does the white "TIMEX" disk rotate around a static dial disk with the numbers on it, or does the numeric plate rotate under a fixed white "TIMEX" disk?
My guess is that the dial is fixed, and the "TIMEX" plate is effectively a circular plastic hour hand with a window that shows the numbers on the dial beneath, in which case it is a very similar arrangement to my tennis playing Snoopy with its transparent second hand with a tennis ball on it.
Edited by AndyHull
Yes the Timex disc rotates around like a minute hand.
A nifty solution, since this allowed them to use a standard mechanism.
Did you find the dial style number?
It will be printed on the metal dial disk down at the 3 O'clock position, and as I said before, you  may not be able to see it without removing the mechanism from the case.
My guess is that it starts with 3XXX the last two digits will be the year of manufacture.
There isn't any numbers anyplace I can see here is photo with dial removed.ea433dbd3a13b3b34d56291326a27aba.jpg&key=9d016f3e262e3e0e41b33e4ebc583d07bd2a86c45022f748b4736da37ec155fe1526e954cfa3f93e4af71d126cb6378e.jpg&key=be32c074b56ef63cc965645c4529d89e5382d5fb8d9ef75ee70ac2d842339ada
I wonder if this is a prototype? An idea Timex toyed around with and developed a prototype and possibly a few sales samples and then abandoned without going into full production. We can estimate the age by the movement, if it dates to the late 60's through the late 70's, then Jump hour/ direct read watches were en-vogue. Many companies develop products without ever going into production, this may very well be such an example.
The number might be visible if the hands were removed, but that seems like a slightly dangerous move.
Typically it would be on the dial plate, so in this case,  the circular hour hand would be covering it completely.
No worries, the exact designation is of purely academic interest. It looks too well finished for a prototype, but you never know of course.
No doubt some former Timex employee (in Dundee perhaps) might know the history of this particular piece.
Having worked for many years in manufacturing, my experience allows me to make a few assumptions. If Timex was ramping up to begin production on this and the market for this type of watch suddenly crashed, (which it did) they would very logically pull the plug on it. There could easily have been a small handful of these of a more refined quality than a crude prototype. It is also logical to conclude a former employee may have ended up with this piece because of their access. In any case, it is an amazing watch.
Today's watch is my vintage Vostok Komandirskie. You may recognize it as the exact model Mark featured in his recent YouTube video with the pallet issue. I liked the one he chose so much, I had to get one for myself. I absolutely LOVE the patina on the dial. As Mark mentioned his was a bit of a Frankenwatch, mine is as well. Amphibia case, Komandirskie movement and dial and a no name bracelet that was once two tone gold and stainless but the gold was scrubbed away. I'm still waiting on my scuba dude like the one mark also featured, but that one is taking the slow road from Russia:rolleyes:
I would  call it an amphibia with a komamdirskie dial. It is after all the case that qualifies it as an amphibia. And since  it is a 24xx movement  current  production  dials from mother  Russia will  fit.very cool.
AS1187 powered  Mondia. This one runs pretty  nicely. About 220 degrees  amplitude  10 seconds  fast at .7 ms beat error..curiously it is all stainless swiss cased..and has an acceptable  beat error. I have noticed  that  very  often  cheaply cased AS1187's  have pretty  large  beat errors. Factory  seconds maybe.Or hasty  off shore  assembly.
Amphibirskie or Komanphibia...hmm:D
    • I need to see photos of the whole movement before I comment.
    • Hi @Jon, so, from one extreme to another the beat error is 0.1(min.pos) to 0.2(msx.pos), and as you mentioned the rate does up and down dramatically. Also checked the position of the collet, and the collet is not central to the jewel on the balance cock. Balance moves freely, per my understanding.   So, after 24h the ampl. fell down by approx 20 deg, which I would assume is expected. After adjusting the endshake I believe I gained around +10 deg. of balance movement. Which is great, and overall the balance is not at 220'ish deg.   What I did next, some might think is non-orthodox, but was wort a try. I too the mainspring out, checked again for endshake and if the pin moves freely, and cleaned everything. Usually when installing the mainspring I would use some barrel grease on the barrel walls, install the spring and put a 2-3 drops of D-5 oil on top of the wounded spring and in the places where the arbor sits. This time I took the spring and applied a ultra this coat of Molykote Dx paste on the whole spring, before installing it in to the barrel, and added some oil to the arbor as usual.  The result improved, at a full wound the balance produces about 230-237 deg. @JohnR725 I'm getting closer to 300 😃   What I am noticing, there is a fluctuation in amplitude. With time it would rise and drop about total 8-10 deg in an interval about 2 minutes. I assumed this ruled out the power transfer from the barrel itself. So I took the gear train out, cleaned and lubed.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
