Watch of Today
mk3
15 hours ago, AndyHull said:
I presume by that, you mean that they would survive a nuclear apocalypse, rather than that they are tasty when fried in a wok.
:D
EDIT: I forgot to mention it also needed the winding pinion replaced as there were teeth missing. I also shortened the stem to the correct length, and re-polished the crystal, so it now looks a whole lot better.
I'll finish adjusting and regulating it tomorrow. The Eden-matic (from the same job-lot) is also going nicely. The pair of them can then join the 404 club.
I have noted a problem  with Russian  keyless  works..As to whether  it is the weakness of the metal  or the strength  of the wearers I have yet to determine. Of course  it should  also be politically  incorrect of me  to cast aspersions  on ethnic  cuisine.
No aspersions need be cast, deep fried cockroaches are real. This from Wikipedia for example.
"... The cockroaches are fried twice in a wok of hot oil, which makes them crispy with soft innards that are like cottage cheese.[92][93] Fried cockroaches are ground and sold as pills for stomach, heart and liver diseases.[94] A cockroach recipe from Formosa (Taiwan) specifies salting and frying cockroaches after removing the head and entrails.[95]In traditional and homeopathic medicine..."
I'm pretty adventurous in terms of what I will eat, and in my travels,  have tried some strange stuff over the years, including seal meat, ostrich, crickets and kangaroo (not all at the same sitting of course). If offered deep fried cockroaches, based on that description, I might be tempted, though not as a solution to any internal medical issues.
As to the cause of the demise of the key-less work of Russian watches, I suspect the lack of proper sealing of the stem is probably a major contributor. On those watches that I have seen this problem (not all Russian), there was evidence of corrosion or ingress of crud, both of which could lead to binding and stripping of teeth. Metallurgy may also be  a factor, particularly if the cause is a snapped spring but I suspect that poor case construction is a more common reason.  Lack of servicing is also likely to be a common cause, since grease tends to turn to tar if not regularly replaced, and once in this state, the wearer will tend to simply put more pressure on the winder in the hope of "freeing it up", which is obviously not a good idea.
There are some things I just wont eat ! for instance a Balut..insects are another thing I will without exception decline to knowingly consume.i also will not eat crabs, they look too much like a spider to be put on my plate.
Edited by yankeedog
spelling
Balut .... Half formed chick in egg ? [emoji40]
1 hour ago, ITProDad said:
How do you polish the glass crystals, if I may use that contradiction...
Rouge? Buffing wheel?
Various threads about that. First, scratches are removed with wet paper, then polish with diamond paste. All that with a rotary tool or bench motor.
9 hours ago, yankeedog said:
Your guess would be correct. Your statement agreed with.
Just to prove yours isn't a fluke, here is my "almost COSC" 1970s Sekonda TV face, which I have literally just taken off my wrist, having worn it all day everyday for the last month, wound and slapped on the time grapher.
.. also giving a not too shabby performance.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
