Watch of Today
mk3
15 hours ago, AndyHull said:
I presume by that, you mean that they would survive a nuclear apocalypse, rather than that they are tasty when fried in a wok.
:D
EDIT: I forgot to mention it also needed the winding pinion replaced as there were teeth missing. I also shortened the stem to the correct length, and re-polished the crystal, so it now looks a whole lot better.
I'll finish adjusting and regulating it tomorrow. The Eden-matic (from the same job-lot) is also going nicely. The pair of them can then join the 404 club.
I have noted a problem  with Russian  keyless  works..As to whether  it is the weakness of the metal  or the strength  of the wearers I have yet to determine. Of course  it should  also be politically  incorrect of me  to cast aspersions  on ethnic  cuisine.
No aspersions need be cast, deep fried cockroaches are real. This from Wikipedia for example.
"... The cockroaches are fried twice in a wok of hot oil, which makes them crispy with soft innards that are like cottage cheese.[92][93] Fried cockroaches are ground and sold as pills for stomach, heart and liver diseases.[94] A cockroach recipe from Formosa (Taiwan) specifies salting and frying cockroaches after removing the head and entrails.[95]In traditional and homeopathic medicine..."
I'm pretty adventurous in terms of what I will eat, and in my travels,  have tried some strange stuff over the years, including seal meat, ostrich, crickets and kangaroo (not all at the same sitting of course). If offered deep fried cockroaches, based on that description, I might be tempted, though not as a solution to any internal medical issues.
As to the cause of the demise of the key-less work of Russian watches, I suspect the lack of proper sealing of the stem is probably a major contributor. On those watches that I have seen this problem (not all Russian), there was evidence of corrosion or ingress of crud, both of which could lead to binding and stripping of teeth. Metallurgy may also be  a factor, particularly if the cause is a snapped spring but I suspect that poor case construction is a more common reason.  Lack of servicing is also likely to be a common cause, since grease tends to turn to tar if not regularly replaced, and once in this state, the wearer will tend to simply put more pressure on the winder in the hope of "freeing it up", which is obviously not a good idea.
There are some things I just wont eat ! for instance a Balut..insects are another thing I will without exception decline to knowingly consume.i also will not eat crabs, they look too much like a spider to be put on my plate.
Edited by yankeedog
spelling
Balut .... Half formed chick in egg ? [emoji40]
1 hour ago, ITProDad said:
How do you polish the glass crystals, if I may use that contradiction...
Rouge? Buffing wheel?
Various threads about that. First, scratches are removed with wet paper, then polish with diamond paste. All that with a rotary tool or bench motor.
9 hours ago, yankeedog said:
Your guess would be correct. Your statement agreed with.
Just to prove yours isn't a fluke, here is my "almost COSC" 1970s Sekonda TV face, which I have literally just taken off my wrist, having worn it all day everyday for the last month, wound and slapped on the time grapher.
.. also giving a not too shabby performance.
    • Thanks for the help guys! VWatchie I already found your thread but I'll check it again. Nice to know about acetone, I still have to get the shellac off since I made a little mess. I adjusted the jewel, put new shellac (the so called soldering technique, pallet tool too hot this time so the shellac "wire" melted in air before getting in contact with jewels or fork) rinsed the pallet fork and put it back dry. Amplitude is now in the 240-250 range that I expected in the first place. I guess there's enough oil in the escape wheel teeth already but I'll check that later. The mainspring was pretty beaten so a new one would probably boost the amplitude even further. Nice to learn new things. Now I have another thing to look for while disassembling. I wonder if the watch left the factory that way.
    • Would be interesting to see it 🙂
    • These are all American movements (with the exception of the "Rubis"), and are all almost certainly "negative set" which means the stem is part of the case. So it's normal that they are all missing- they are with their cases. You will need male square bench keys to wind/disarm them. Vintagewatchstraps has a great writeup on the different systems. But basically, any American "x" size movement will fit any case for that size, possibly with some adjusting of the stem position. With Swiss movements, there is some interchangeability between calibers, usually within the same maker's range, but not really overall- there are thousands of different stems out there.
    • Hi, I'm very new to watchmaking and this is my first time posting here.  I've bought a lot of 10 vintage pocket watches size 0s from e-bay and just got them today.  Most of the balance wheels sprung quite freely and thus seemed like a worthy endeavor as a first batch for exploration.  I've just realized that none of them have any winding stems. Is there any way I could source appropriate winding stems for the movements? There seems to be assortments of various stems selling in bulk on aliexpress, but would any of them fit?  I've read on other threads that some people lathe their own stems (which is waaaay out of my current skill set, which is pretty much nil). Others say that you 'just have to try a few and see if they fit'. I would much appreciate any advice for this matter. Thanks!
    • Nice work.  In the last year, I have been servicing Accutron 218s.  I have the official Accutron hoder that provides electrical contact to the movement.  It is a pretty clever design.  There is a cut in the ring of the holder (shaped like a "C").  When in relaxed state, the holder is slightly smaller than the watch movement.  You spread the cut slightly and drop the movement in and release.  Very clean.  I have made 3D versions of this setup.  Have not explored using it generally for other movements.
