Watch of Today
mk3
7 hours ago, AndyHull said:
Another of those whodunit watches. This time an Eden-matic 21 jewel automatic joins the club. The amplitude is a little low at around 255 but other than that it seems to have enjoyed its clean and lube session, and a new crystal has brought up the dial quite nicely.
The strap is borrowed from a digital, but I'll pop it on a leather one, once it has settled down and be regulated and adjusted to my satisfaction.
I can find very little information about this particular brand, so any clues would be very welcome.
What's  under the  hood?
Scraping away layers of paint and grime, revealed this 1978 Timex Marlin front loader. Dead as a door nail, and fully wound when it arrived, it is now running well.
It obviously still has a few battle scars, and the crown needs some attention, but what would a vintage watch be, without a little age related character.
20 hours ago, m1ks said:
Bfg866 pin pallet.
I was unfamiliar with the name but bought this because I liked the design over typical jump hour watches. Marked swiss on the dial.
I have trouble  reading things  like small numbers  without  reading  glasses  with a standard  analog watch I have no trouble.
Today this ThusyT from probably around 1950, with its fair share of age-associated patina and, at 37mm, a big boy for its time. Like this one, the few I’ve seen of this brand seem to have mainly been sold from Italy and whilst the name is recorded in Mikrolisk, the maker is shown as “unknown” but speculated to have been Swiss.
Today’s effort is another example of mismatched jewel counts between dial and movement and despite the “206” on the bridge, is running on a 13’’’ Unitas cal. 176, unfortunately not represented in either R.R. or Lorenz. An alternative version of the 176 is shown in a German archive but with “207” on a substantially different bridge configuration from mine.
Concluding today’s little mystery, a Thusyt watch driven by an AS 1203 movement is featured in a short YouTube video (why??) without dialogue but captioned in Portuguese.
Regards.
On ‎10‎/‎11‎/‎2019 at 1:43 AM, m1ks said:
Bfg866 pin pallet.
Possibly Swiss-made by the Basis Watch Co and then branded for Willy Herman’s London-based Trafalgar Watch Co, distributors of watches at the OMG end of the spectrum. The entrepreneurial Willy and his watches apparently did good business with Messrs. Tesco (other Supermarkets are available).
Regards.
Regards.
Thanks, interesting info.
Another Timex novelty watch, with a cow, and a fly... nope I have no idea why.
This arrived with the battery retaining clip missing, so I had to fabricate one.
Rather fittingly, since I had no brass sheet thin enough,  I resorted to a small piece of the lid of a can of sardines, rescued from the trash.
https://www.youtube.com/watch?v=kiKLDkO-0rQ
The paint was sanded off, then the metal was tinned with the soldering iron and cut/filed to shape, so If you see a bunch of flies following me around, there may be a reason for that. They are either after the watch, or more likely, the sardines. :wacko:
Edited by AndyHull
  • Haha 2
All the neighbourhood cats will love you.
46 minutes ago, yankeedog said:
And , you are not showing us your work???????
Just to prove there was nothing fishy about my last post, I wouldn't want you to think I was skating round the problem, or conning you hook, line and sinker, here are a couple of images trawled from my image stash.
.. and some suitable musical accompaniment..
Back to the Eden-matic today.
Its a lot healthier than it was, and running fairly well, but the amplitude is a little on the low side, hovering around 200(°) - 220(°) dial up, and a little worse, dial down.
I'll wear it tomorrow and see if it settles down, before sorting out that rather large rate error.
I'm wondering if I need to re-visit the mainspring.
I also found out a little more about the maker. It seems that Eden and Eden-matic were brand names of Fabrique d’Horlogerie B. Gisiger-Greder (Gisiger-Greder Watchmakers), from Selzach (in the Solothurn canton north western Switzerland).
More of their brand names here -> http://www.mikrolisk.de/show.php?site=280&suchwort=Gisiger-Greder&searchWhere=all#sucheMarker
The company seems to have vanished sometime after 1975, so presumably yet another victim of the quartz crisis.
Edited by AndyHull
I sorted another one of these 19 Jewel Raketa 2609HA based Sekondas a while back.
This latest one was in a job lot, and as well as the usual layers of filth, it was missing its stem and crown.
The dial had a bunch of nasty black and grey dots and scratches, the majority of which which were carefully masked with thinned white nail polish.
The crystal still needs a final polish, and the stem is about 1mm too long, but its going nicely.
40 minutes ago, yankeedog said:
The cockroach  of watches.
I presume by that, you mean that they would survive a nuclear apocalypse, rather than that they are tasty when fried in a wok.
:D
EDIT: I forgot to mention it also needed the winding pinion replaced as there were teeth missing. I also shortened the stem to the correct length, and re-polished the crystal, so it now looks a whole lot better.
I'll finish adjusting and regulating it tomorrow. The Eden-matic (from the same job-lot) is also going nicely. The pair of them can then join the 404 club.
Edited by AndyHull
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
    • Why just the bottom mike ? Is it worth polishing the whole arm ?
