Watch of Today
mk3
4 hours ago, balaton said:
Blimey, I see what you mean.
What you've got there would appear to be two French-made Framelac pin-levers, a movement maker about which very little seems to be recorded. I've attached an image from the Uhrforum.de of the jewelled-lever FR 304 for comparison of the bridge configuration (similar) and the shape of the balance cock (identical).
Thanks for the info. The Rodeo is remarkably similar to this.
https://www.uhrwerksarchiv.de/movements/c/crc/crc-960/
.. but perhaps is closer to this.
https://17jewels.info/movements/c/crc/crc-860/
It has the cruder balance, but a different "shock" spring arrangement as opposed to what looks suspiciously like glue on the example here.
The "LiJac" is certainly from the same stable, but even simpler in its construction.
Well, that's pretty convincing and I think you've nailed these oddities!
I certainly don't have any examples of them in my collection of old nonsenses. Neither, obviously, does Ranfft, so well done Chris Lorenz.
Cheers.
Edit: This in response to @AndyHull last posting
Edited by balaton
add text
Long time since I popped a pic of a watch here .. but today I thought I'll hang a noname watch around my wrist.
The Purple danger has a modified 2824-2 raving under the hood, the date function har been removed ;)  .
An "almost new" HMT Janata today. It did require a service and a bit of a polish to get it to this state, but I'm pretty pleased with the result. This one appears to be completely original.
I have a bunch more HMTs waiting in the wings to join the 404 club, I'm just a little short of that all important ingredient "spare time" at the moment. I'll post the rest when I get a chance to work on them.
Love the art deco numbers [emoji106]
3 minutes ago, ro63rto said:
Also waiting in the wings (pun intended) is this near identical white dial version.
I've not had a chance to work on that one yet, but it is probably going to be the next victim on the healing bench.
Today, a 38mm Aidix, attributed to Rene Brandt and running on an unusual variant of the 14’’’ 15j ETA 853.
So far, the earliest confirmable date of brand registration recorded has been 1952, but I would have tended to put this particular example in the previous decade.
Regards.
Regards.
Nice sunburst dial, and I've always preferred sub seconds in a dress watch. The movement reminds me of the AS 1130
J
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
